    Display terminal (tty) on CoreMP135 buildin display
    Cores
    5.3k
    • J
      johan_s
      I am running a CoreMP135 with the M5 debian image (kernel 5.15). I am interacting with the device over USB-C / serial tty. How can I show the tty terminal on the buildin display? If connect an external monitor via hdmi it will directly show a tty terminal on the external monitor, can i get the same output on the ILI9342C LCD?
        ajb2k3 @johan_s
        @johan_s You will need to create a program that to capture the the terminal and display it.
        • J
          johan_s @ajb2k3
          Hi @ajb2k3 can you elaborate?
          I think it should be possible to get a terminal on the LCD using the tools provided by the linux distribution. What i gathered from searching on google, is that fbcon can be used to display terminals on framebuffers (such as the ILI9342C). Unfortunately, fbcon is not included in the CoreMP135 Debian image. I am now playing around with the CoreMP135_buildroot repo to see if I can compile it there. I will keep digging.
            ajb2k3 @johan_s
            @johan_s unfortunately I only know the theory and haven’t had much time to work on documentation as having to move my hose and office around. I started looking into the firmware and I/o control just didn’t get very far. I need to dig through not the Devicetree and display code.
            Have you tried installing FBCon yet?
            J 2 Replies Last reply Reply Quote 0
            • J
              johan_s @ajb2k3
              Hi @ajb2k3 , ok that makes sense, no problem.
              Yesterday, I tried a to use the fbterm because it is included in the Debian repo (easy to install with apt), but I unfortutaly I could not get it work.
              I have been looking for fbcon in the buildroot configuration menu but I have not been able to find it so far. But I have noticed that buildroot under kernel extensions include an optoin to compile FB TFT drivers. I will try and recompile with the FB TFT drivers tonight.
              I will post updates here.
              The CoreMP135 is a cool little device, but it is not as easy to use as the other M5 controllers.
              • J
                johan_s @ajb2k3
                @ajb2k3 OK, I figured it out using FbTerm, see my notes below. Just a note to temper expectations: The device is not very powerful (surprise). In my case, I am running Debian, connected to two tty terminals (ttyGS0 over USB-C and tty1 being shown in display), connected over WiFi dongle, and added a BT dongle for keyboard/mouse, and as a result the CoreMP135 very easily becomes sluggish and quite warm.
                Anyway, here are my notes
                Showing a terminal on the LCD TFT display
                Very briefly:
                • The CoreMP135 contains a ILITEK ILI9342C LCD TFT display with touch
                • The Debian OS recognizes as the display as a framebuffer and makes it accesible at /dev/fb1
                • Low level interaction directly with fb1 is below, see examples below. In all the included examples, I was signed in as root via the USB-C interface (ttyGS0)
                # signed in as root
                cat /dev/zero > /dev/fb1 # clear display
                cat /dev/urandom > /dev/fb1 # show random 'static' on display
                echo "HELLO WORLD" > /dev/fb1 # will show some extremely small in the top left corner - not discernible
                • The M5Stack CoreMP135 Debian image includes fbv - a program for rendering .jpg on the framebuffer (TFT LCD). Example:
                # signed in as root
                . /usr/local/m5stack/bashrc # prepare environment for using fbv
                /usr/local/m5stack/bin/fbv /root/mycoolpic.jpg # display .jpg on framebuffer, might only show part depending on jpg resolution
                • It is also possible to show a (somewhat) fully functional terminal on the TFT LCD display using the fbterm program:
                # signed in as root
                apt install fbterm # install FbTerm
                export FRAMEBUFFER=/dev/fb1 # Tell FbTerm to use fb1 as framebuffer
                fbterm -s 12 < /dev/tty1 & # Tell fbterm to diplay tty1 terminal on fb1 with size 12.
                • Connect a BT keyboard or similar and enjoy a somewhat functional terminal
                • One final note: I added root to the video group, although this should not be required.
                  ajb2k3 @johan_s
                  @johan_s I saw the export frame buffer on the CM4 stack but haven’t had time to look into it as moving around the house. Thanks for continuing the work in my steed
                  • P
                    prima
                    I haven't tested yet but on other devices I usually start programs from the serial console or SSH just by adding CLI arguments like this:
                    FRAMEBUFFER=/dev/fb1 <some command>
                    • J
                      johan_s @prima
                      @ajb2k3 no problem my friend
                      @prima I tried your suggestion but I can't really get it to work.
                      With the method I outlined the terminal works fine, but the keyboard input (USB keyboard) is not so reliable. It stop registering keystrokes after a short period. Not sure if the keyboard input get redirected to another terminal in the background or something.
                        ajb2k3 @johan_s
                        @johan_s Hi John sorry for the long delay.
                        I had a chance to play with the frame buffer today after remembering this conversation.
                        I am finding the issue with the small text/garbidge written to the screen that you shared and looking into it.
                        Thanks for the point out.
