    MQTT
    26 Posts 5 Posters 113.6k Views 1 Watching
      ajb2k3 @gadjet
      @gadjet ah that explains it, I’m still running 1.0 as I haven’t had the time to update devices yet.
        Sarcasm funny that it works after the update Sarcasm
        Thanks, Gadget, can I use this demo in my book.
        still cant get the neopixel to work
        • G Offline
          gadjet @ajb2k3
          @ajb2k3 I'm using this flow and it works with a single RGB LED plugged in the grove port A
          RGB LED Flow
          Last night it would only work with the play button and not the download option, now it works with both ???
            ajb2k3 @gadjet
            @gadjet
            Ok something is missing that set the topic to on or off.
            • G Offline
              gadjet @ajb2k3
              @ajb2k3 said in MQTT:
              @gadjet
              Do you mean in the image I posted? that's just a flow to switch a neopixel LED on/off, no MQTT intervention.
                ajb2k3 @gadjet
                @gadjet
                Hmn, I need to play then.
                  dvd78 @jpilarski
                  @jpilarski said in MQTT:
                  You have to save the file to your board. Don't use run. Once it reboots it will connect to wifi and then run the mqtt blocks.
                  Hi @jpilarski, how can i save the file? don't i only need to do "download" from "http://flow.m5stack.com"?
                  i have a project working great if i download it from http://flow.m5stack.com, but when i reboot the M5Stack my module won't start...
                  Best
                  Davide
                    ajb2k3 @dvd78
                    @dvd78 said in MQTT:
                    Best
                    Davide
                    You need to connect you M5 to UIFlow, click the download button (a rough WIP guide is in my WIP Handbook on pages 7, 8, and 9)
                    You need to click the 3 horizantal lines to get the settings up and then click download.
                    When the M5 Stack restarts you need to hit the middle button (B) to get the app list then use the right button (C) to move down and then B to run the program.
                      dvd78
                      thank you @ajb2k3... is there a way to start the m5 immediately with your program?
                        ajb2k3 @dvd78
                        @dvd78 I think.....
                        If you just power it on it should autoload the program.
