    UIflow 1.0 Run looks perfect, download everything scrambled
    5 Posts 3 Posters 2.5k Views
    • G Offline
      G3D_Design
      I am having a problem when I download using UIFlow, when I run from the program it displays everything correctly in the right location. When I download it copies the location of the buttons, text, lines etc as shown on the UI. As I have lots of menu pages I have written the physical locations of each item and then moved them to the edges of the UI screen. I have to do this as it is so full you cant use the click and drop function when adding new buttons etc. Is there a way to make the UI objects locations be ignored when downloading?
      • E Offline
        elektron2kim
        They are messing with it at the moment. Weird policy. Ruined my day.
        • G Offline
          G3D_Design @elektron2kim
          @elektron2kim That's not good. Where did you hear this? Is there any update on when the problem will be solved?
            ajb2k3 @G3D_Design
            @G3D_Design They are not messing with it, they are updating the servers, normally happens about once a week.
            • G Offline
              G3D_Design
              Found a solution, so this is now closed.
              The fix for me was enabling wifi at the start of my code, I knew I needed wifi for the RTC functions but assumed it wouldn't affect positioning of objects, but it did. I added a check loop to make sure wifi is connected before proceeding.
