    lowest power m5paper?
    7 Posts 3 Posters 5.1k Views 1 Watching
      frank_b
      hello
      m5paper's display does not need power to keep displaying... i only want to update the info on screen every so often (e.g. every 10s)
      i am using the light sleep right now:
      gpio_hold_en((gpio_num_t)M5EPD_MAIN_PWR_PIN);
      esp_sleep_enable_timer_wakeup(10 * 1000000);
      esp_light_sleep_start();
      i read somewhere that the power to the screen can be disabled with M5.disableEPDPower(). that seems to work but how do you get i back on? there is M5.enableEPDPower() but that doesnot seem to be enough?
      also: i have a gps attached and i see that that is still powered. is there a way to power down port.C?
      any other things that can be powered down?
      when this all works and is still nog good enough i will try to store state in eeprom and actually power down...
      thanks
      frank
      • felmueF Online
        felmue @frank_b
        Hello @frank_b
        Re enable power to the screen: what do you mean M5.enableEPDPower() isn't enough?
        Re Groove ports: you can only turn off all three ports together. Try M5.disableEXTPower().
        BTW: Only fully powering down M5Paper will give you lowest power. At the time I did some measurements. You can find them here.
          frank_b @felmue
          @felmue said in lowest power m5paper?:
          hi felix,
          turning off external power works. great!
          about turning back on the screen, please see code and screen pictures below. without M5.disableEPDPower() and M5.enableEPDPower() it all works nicely. with turning on/off the screen i do see sort of that it is running but the screen does not "work" properly - i.e. i do not see the number increasing. (and "the noise" is getting worse over time). what am i doing wrong?
          thanks
          frank
          #include <M5EPD.h>
          #include <EEPROM.h>
          // m5paper
          M5EPD_Canvas canvas(&M5.EPD);
          int count;
          int boot;
            M5.EPD.SetRotation(0);
            // cleanig the screen by alternating all pixels set, all pixels reset
            M5.EPD.Clear(true);
            // use rtc
            M5.RTC.begin();
            canvas.createCanvas(960, 540);
            canvas.setTextSize(8);
            canvas.clear();
            canvas.drawString("Sleep Test...", 50, 50);
            canvas.pushCanvas(0, 0, UPDATE_MODE_DU4);
            delay(1000);
            EEPROM.begin(10);
            boot = EEPROM.read(0);
            boot++;
            EEPROM.write(0,boot);
            EEPROM.commit();
            count = 0;
            canvas.clear();
            char printBuffer[64];
            sprintf(printBuffer, "b=%d, c=%d",boot, count);
            canvas.drawString(printBuffer, 50, 50);
            count++;
            delay(1000);
            esp_sleep_enable_timer_wakeup(5 * 1000000);
            // turn off power to screen
            // M5.disableEPDPower();
            // turn off power to ports
            M5.disableEXTPower();
            // sleeps, wakesup and continues
            // sleeps, wakesup and restarts
            // esp_deep_sleep_start();
            // shutsdown
            // M5.shutdown(5);
            // turn on power to screen
            // M5.enableEPDPower();
            // turn on power to ports
          without turning off/on power to screen:
          with turning off/on power to screen:
          • felmueF Online
            felmue @frank_b
            Hello @frank_b
            please find an explanation here. (It's for M5CoreInk, but I think the same thing is happening here.)
              frank_b @felmue
              @felmue: nice!
              just added a redraw of the screen and it all works:
                // redraw screen
                M5.enableEXTPower();
              the screen does get a bit of greyish line pattern over time:
                ajb2k3 @frank_b
                @frank_b normally with EInk you have to make a HV write to set the ink on the screen then you can switch the device off while still keeping the image or text on screen. If you do a normal write then the content will fade or just vanish when powered off.
                  frank_b @ajb2k3
                  @ajb2k3 thanks!
                  any idea how to do this with the M5Paper?
                  cheers
