    M5GO Battery Bottom3 (for CoreS3 only) with CoreS3 issues
    5 Posts 2 Posters 3.6k Views
    • Coopersmith-24601C Offline
      Coopersmith-24601
      M5GO Battery Bottom3 (for CoreS3 only) was delivered today for my CoreS3. Also delivered was a M5GO/FIRE Battery Bottom Charging Base
      I installed it and while the battery is working, when I put it on the M5GO/FIRE Battery Bottom Charging Base the USB-C charging input doesn't deliver charge to the battery nor data.
      Further, I assumed the LEDs included in the M5GO Battery Bottom3 (for CoreS3 only) would be useable with the RGB function of UiFlow2, but this doesn't seem to work.
      Do I need to do something special with the CoreS3 to get these functions to work?
        felmue @Coopersmith-24601
        Hello @Coopersmith-24601
        Re charging: the M5GO3 has its own charger IC built-in. A red LED indicates charging and when the battery is full the green LED in M5GO3 lights up. The built-in charger IC cannot be queried by software; is that what you mean by 'data'?
        Re RGB: please find an example in the UIFlow2 Project Zone: M5CoreS3_M5G03Bottom_RGB_UIFlow2.1.3
        Coopersmith-24601C 1 Reply Last reply Reply Quote 0
          Coopersmith-24601 @felmue
          Thank you for that programming example. It cleared up how to use the RGB LEDs and that's great!
          However, I still have an unresolved issue with the M5GO/FIRE Battery Bottom Charging Base; https://shop.m5stack.com/products/battery-bottom-charging-base
          If I plug a USB-C cable into it, the power doesn't pass power to the M5GO Battery Bottom3 (for CoreS3 only) through the pogo pins and doesn't charge its 500mAh battery; https://shop.m5stack.com/products/m5go-battery-bottom3-for-cores3-only
          Just to be clear, I'm also using these with a CoreS3; https://shop.m5stack.com/products/m5stack-cores3-esp32s3-lotdevelopment-kit
          I've removed the CoreS3 bottom and replaced it with the M5GO Battery Bottom3 (for CoreS3 only). If I attempt to use the USB-C port on the M5GO/FIRE Battery Bottom Charging Base, just like the power issue above, I also can't use it to send firmware to the CoreS3 (which is what I meant in my previous post by data). It's as if the M5GO/FIRE Battery Bottom Charging Base is entirely useless for either charging the battery or programming. That doesn't seem like it should be the case at all.
            glad to hear that the RGB example helped.
            The four pogo pins are GND, 5V, SDA and SCL. E.g. power and I2C. See top right corner of schematic - Socket_Power_4P.
            Firmware download uses a serial connection and not I2C. In other words the M5GO/FIRE Battery Bottom Charging Base can only be used to charge the battery.
            Edit: I just confirmed by opening it: only GND and 5 V are connected at the USB-C port.
            How do you know the battery isn't getting charged? Isn't there a red (or green) light?
              OKAY! Excellent. THANK YOU. Didn't understand the USB-C port on the charging base.
              Figured this all out with your help and appears to need to be fed the power from the included "dumb" USB-A to USB-C cable and not what I thought I could do from an Apple USB-C / USB-C plugged into my MacBook.
              Problem solved!
              Thank you again!
