Sharing Code for RC Servo tester
Hi.
I just start code m5stack for 2 day (My model is m5stack fire).
This code support 3 mode .-
Manual Mode. You can set RC servo from 0 to 180 degree.(10 degree per step.)
Center Mode. This mode will lock servo at 90 degree.
Sweep Mode. This mode will loop sweeping servo to 0, 90 and 180 degree then sweep back to 90 and 0 degree.
Well, that’s a bit more interesting then my attempt at a servo tester. Thank you for sharing. Do you mind if I add it to the UIFLOW handbook?
Very cool, could i add it in uiflow example
@pattiuak said in Sharing Code for RC Servo tester:
Hi.
Ahh, wrong port was set, now working on the Black Core.
@ajb2k3 I don't mind. Please do it.
@heybin Please do it.
Thank you Very Much!
