    Thingspeak API - multiple fields
    3 Posts 2 Posters 2.0k Views
      m5oss
      I'm stuck on a problem sending data on the thingspeak platform (ENV â…£ Unit).
      I can't send multiple data at the same time on thingspeak. On the other hand, only one data works.
      Examples (url_thingspeak):
      1. only one send works:
      http://api.thingspeak.com/update?api_key=AS000000001&field6=1
      2. Multiple data sends do not work, I tried several solutions:
      http://api.thingspeak.com/update?api_key=AS000000001&field6=[pression]&field7=[temperature]&field8=[humidity]
      http://api.thingspeak.com/update?api_key=AS000000001&field6=' + pression + '&field7=' + temperature + '&field8=' + humidity
      http://api.thingspeak.com/update?api_key=AS000000001&field6= + pression + &field7= + temperature + &field8= + humidity
      This may be a basic question, but I can't find the solution as a beginner :-(.
      Thanks for your help
      • felmueF Online
        felmue @m5oss
        Hello @m5oss
        try something like below:
        or try using an Execute Code block with this content:
        url_thingspeak = 'http://api.thingspeak.com/update?api_key=A00000056&field1=' + str(pression) + '&field2=' + str(temperature) + '&field3=' + str(humidity)
          m5oss @felmue
          Hello @felmue
          Thanks for your help.
          Everything works with this solution :-) :
