    m5stack ToF vl53l0x unit will stop scanning I2C devices
    11 Posts 3 Posters 27.4k Views 1 Watching
    • m5-docsM Offline
      m5-docs @vvs551
      @vvs551
      Hey, Here's my result. My Gray Core works well.
      https://github.com/tackelua/I2C_Scanner/blob/master/I2C_Scanner.ino
      M5Stack documentation URL
      https://docs.m5stack.com
      V 1 Reply Last reply Reply Quote 0
      • V Offline
        vvs551 @m5-docs
        @watson without any chance for me
        With ToF unit connected:
        With disconnected ToF unit:
        What is 0x75 in your listing?
        • m5-docsM Offline
          m5-docs @vvs551
          @vvs551
          0x75 is the address of IP5306 IC. Because this IC is customized. It is designed to communicate with M5Core through IIC.
          • V Offline
            vvs551 @m5-docs
            @watson Did you mean battery extension?
            I have not 0x75 when scan I2C
            m5-docsM 2 Replies Last reply Reply Quote 0
            • m5-docsM Offline
              m5-docs @vvs551
              @vvs551
              Hey, IP5306 was built in M5Core board without battery extension.
              How about M5Core running with I2C_Scanner.ino without any unit?
              IP5306 was built in M5Core Fire, so the terminal will display two I2C addresses: 0x68(MPU9250), 0x75(IP5306).
              IP5306 was built in M5Core Basic, so the terminal will display one I2C address: 0x75(IP5306).
              • m5-docsM Offline
                m5-docs @vvs551
                @vvs551
                What's the hardware version of your basic core?
                • V Offline
                  vvs551
                  0_1548143397290_d5fe9e38-2c31-4edd-b090-5f320f23db88-image.png https://photos.app.goo.gl/xQVAn8TftW32pEfz9
                  • V Offline
                    vvs551 @m5-docs
                    @watson there is scanning just 0x68 without any units/
                    You can see this listing in previous post
                      PlayTheGame
                      @vvs551 Could you make a picture of the TOF PCB? The schematics are not yet available
                      I have a hypothesis on all this I2C issuses.
                      But before just to exclude software bugs, please check to use the latest ESP32 Arduino core, at least V1.0.1 https://github.com/espressif/arduino-esp32/releases including all the recent I2C fixes.
                      • V Offline
                        vvs551 @PlayTheGame
                        @playthegame thank you for help!
                        I updated esp32-arduino with this link - nothing happens
                        The same result - just 0x68 in I2C scanner listing(
