    M5Dial external i2C (port A) with Arduino Wire
    4 Posts 2 Posters 2.8k Views
      minieigi
      I want to use a I2C CAN Bus Module https://docs.longan-labs.cc/1030017/ connected to the port A on the M5Dial.
      The Longan_I2C_CAN_Arduino lib uses the Arduino Wire lib.
      I get the following error probably because It uses the internal I2C.
      Guru Meditation Error: Core  1 panic'ed (IllegalInstruction). Exception was unhandled.
      Memory dump at 0x4200f55c: e2e502ad 000000ff fd004136
      in the main.ino file I declare a second Wire instance and initialize it with the pins used on the M5Dial.
      TwoWire i2Ctwo(2);
      I2C_CAN CAN(0x25, &i2Ctwo); // Set I2C address and Wire instance
        int8_t SDA_2 = M5.Ex_I2C.getSDA(); // 2 (G13)
        int8_t SCL_2 = M5.Ex_I2C.getSCL(); // 3 (G15)
        i2Ctwo.begin(SDA_2, SCL_2);
      But the M5Dial class uses already the I2C_Class instead of the TwoWire class.
      // for external I2C device (Port.A)
         I2C_Class &Ex_I2C = m5::Ex_I2C;
      I modified the I2C_CAN lib to be able to pass a TwoWire * pointer.
      I2C_CAN::I2C_CAN(unsigned char __addr, TwoWire *__i2c = &Wire)
          IIC_ADDR = __addr;
          i2C = __i2c;
      void I2C_CAN::begin()
          i2C->begin();
      void I2C_CAN::IIC_CAN_SetReg(unsigned char __reg, unsigned char __len, unsigned char *__dta)
          i2C->beginTransmission(IIC_ADDR);
          i2C->write(__reg);
          for(int i=0; i<__len; i++)
              i2C->write(__dta[i]);
          i2C->endTransmission();
      Has anyone tried to use a I2C extension on port A with a standard Arduino lib? Any help would be appreciated.
        felmue @minieigi
        Hello @minieigi
        have you tried to simply use Wire? E.g.
        //  i2Ctwo.begin(SDA_2, SCL_2);
          Wire.begin(SDA_2, SCL_2);
        In addition you could also try to first release/end the predefined Wire:
          M5.Ex_I2C.release();
          minieigi
          If I leave the Longan_I2C_CAN_Arduino lib unchanged I get one CAN message before the device reboots and I see the error I posted above.
          It seems the standard Wire pins are configured properly.
          If I add Wire.begin(2, 3) the device is not even starting Serial debug.
          M5.Ex_I2C.release(); is not making any difference.
            felmue @minieigi
            Hello @minieigi
            you are correct, the standard Wire pins are configured correctly for port A, but in your case you don't want the I2C_Class wrapper from M5Unified. So the idea is to release/end Wire as it has been initialized in M5.begin() and then restart Wire by calling Wire.begin(13, 15).
            And yes, I think the release() is done automatically when Wire is re-initialize.
            Note: I don't have this particular sensor so I cannot fully test this myself.
