    Atom S3R - Screen Dead on Arival
    Atom
    994
    • K
      Kramph
      I received an Atom S3R and the screen doesn't work. I've erased and installed the correct firmware and still no screen. Anyone know any tricks to get working?
      • kurikoK
        kuriko
        Hi Kramph,
        Have you tried to burning the UIFlow firmware? Does the device appear in the UIFlow device list?
        • K
          Kramph @kuriko
          @kuriko
          It does appear in the device list and I've flashed it with the proper firmware through the UIFlow program. Even tried erasing first. M5 sent me a coupon to replace it, but there's no Atom S3R's in stock right now. Will get a new one when they are available.
          • A
            atmozphera
            I also have a recently purchased AtomS3 (about 2 months ago) and today, out of nowhere, the screen died and nothing appears anymore.
            Nothing bad was done on it, a project was running normally. I've done everything until now:
            • I've reset it, nothing work.
            • I flashed the project again successfully (its hit 100% but nothing appears on the screen.
            I did the reset, erase, etc, etc.. and nothing.
            Other projects, such as Ui2Flow2, load 100%, without any errors, but nothing is displayed on the screen. Leading me to believe that the screen simply burned out.
            Is there anything else I can try or should I throw it in the trash?
            Best regards,
            • kurikoK
              kuriko @atmozphera
              @atmozphera
              Since you have tried so many things, it should be determined that this is a hardware problem and you should contact the seller.
              • A
                atmozphera @kuriko
                @kuriko I bought it at the M5 store and as returning the item is impossible, I will have to throw it in the trash. Here's a tip NOT to buy the AtomS3, because from what I've seen, it's a chronic problem with the device and a lot of people have the same problem
