    M5 Scale with M5Atom Lite
    3 Posts 3 Posters 2.1k Views
      mtrehy
      I have an M5scale and an M5 Atom Lite, also connected to a Grove Led Bar V2.0.
      The led bar has 10 led's and I want all 10 illuminated when less than 50g is placed on the scale and no led's illuminated when more than 475g is on the scale.
      I have tried to program with Arduino but keep getting errors. I'm very limited with programming. Is what I am trying to do achievable? Any help greatly appreciated.
      kurikoK felmueF 2 Replies Last reply Reply Quote 0
      • kurikoK Offline
        kuriko @mtrehy
        Hi @mtrehy
        The function you want to achieve is very simple, don't worry.
        If you are using UNIT Scale, you may consider programming with the UiFlow graphical interface, which is much easier than Arduino.
        https://flow.m5stack.com/
        • felmueF Online
          felmue @mtrehy
          Hello @mtrehy
          have you tried to connect only one of the two (M5Scale or Led Bar) to your M5Atom and see if you can make one work at the time?
