    Issue with default Serial
    Atom
    1.8k
      mrtof
      Has anyone experienced error in Serial data transmission from an Atom Lite BUT ONLY when you simultaneously send Serial data to the Atom?
      I have tested different boards (Teensy, Arduino NG, Arduino Nano), and this is the only one that has this issue.
      I wrote about it here : https://github.com/m5stack/M5Atom/issues/86
      If the computer does not send data to Atom Lite, the Atom send the sequence 0 to 255 without a problem.
      But when I simultaneously send data from the computer to the Atom Lite, there is errors on the sending of the sequence from the Atom Lite.
      What do you think is going on?
      • kurikoK
        kuriko @mrtof
        @mrtof
        Have you tried using other GPIO as serial port? As far as I know, the default serial is internal, and there may be other data interference.
          mrtof @kuriko
          @kuriko This seems to be related to the code on the CH552T chip onboard the M5Stack Atom Lite that emulates an FTDI chip (it is not an authentic FTDI chip!!!). There are packet losses when data is being sent and received simultaneously over USB serial.
