    M5CoreInk RTC doesn't wakeup when connected to USB
    General
    • B
      bsmorgan
      I have a modified version of the RTC_Clock example and it doesn't wakeup after an M5.shutdown(55) when it is connected to USB. If I disconnect the USB cable, the sketch works.
      The same behavior when I use the unmodified example. The RTC_Wakeup example also exhibits the same behavior.
      This makes it impossible to use Serial.print debug statements.
      Happy to include my modified sketch when I have the privileges to do so.
        felmue @bsmorgan
        Hello @bsmorgan
        well, M5CoreInk cannot shutdown in the first place when running from USB - see schematic here.
        A modified USB-C cable (with 5 V line cut) might help with debug statements in this case.
