    M5Stick randomly wakes from deep sleep
    M5 Stick/StickC
    7.6k
    • mocmM
      mocm
      I tried to put the M5Stick into deep sleep and found that it randomly wakes up after a while without any trigger or timer set.
      I am using the Arduino IDE and tried deep sleep and light sleep and it always wakes up after a while (not constant time).
      I tried it on the gray and the white model with the same result. It happens with and without USB power. Any ideas as to why that happens? I just want it to sleep until reset is pressed.
      • m5-docsM
        m5-docs @mocm
        @mocm
        How about your code?
        However, you can try this code for your m5stick.
        https://github.com/m5stack/StickWatch
        M5Stack documentation URL
        https://docs.m5stack.com
        mocmM 1 Reply Last reply Reply Quote 0
        • mocmM
          mocm @m5-docs
          @watson said in M5Stick randomly wakes from deep sleep:
          Thanks,
          I tried the StickWatch sketch and in this case the deep sleep seems to work. I compared the code, but could
          not see any differences. So I have to check again. Are there any sleep settings kept in SPIFFS ? If so,
          changing the memory config for the StickWatch sketch may have overwritten them and fixed the
          problem.
          • m5-docsM
            m5-docs @mocm
            @mocm You can talk with eggfly by github.
            https://github.com/eggfly
