    [M5CoreS3] No UART on Port.C of DIN BASE
    Cores
    769
    • G
      Girgitt
      Hi There,
      I am having issue with CoreS3: UART on Port.C does not work in Platformio with Arduino framework.
      The same code works with Core2 v1
      Already tried swapping pin 17 and 18 but nothing on the oscilloscope.
      Already tried using serial2 instead of HardwareSerial 2.
      Did anyone face similar issue?
      main.cpp:
      #include <Arduino.h>
      #include <Wire.h>
      #include <M5Unified.h>
      #define CORE_S3
      #ifdef CORE_S3
          static const int SERVO_UART_TX = 17;
          static const int SERVO_UART_RX = 18;
      #elif defined CORE_2
          static const int SERVO_UART_TX = 13;
          static const int SERVO_UART_RX = 14;
      #endif
      //HardwareSerial SerialServo(2);
          M5.begin();  // Init M5Core.  εˆε§‹εŒ– M5Core
          // Serial2.begin(unsigned long baud, uint32_t config, int8_t rxPin, int8_t
          // txPin, bool invert)
          Serial.begin(115200);
          // Serial2.begin(115200, SERIAL_8N1, 13,
          //               14);  // Init serial port 2.  εˆε§‹εŒ–δΈ²ε£2
          Serial2.begin(1000000, SERIAL_8N1, SERVO_UART_TX, SERVO_UART_RX);  // Init serial port 2.  εˆε§‹εŒ–δΈ²ε£2
        M5.Lcd.printf("Started");
        delay(200);
          Serial.write("aaaaaaaaaaaaaaa");
          Serial2.write("bbbbbbbbbbbbbb");
          delay(100);
      platformio.ini
      [env:m5stack-cores3]
      monitor_speed = 115200
      monitor_dtr = 0
      monitor_rts = 0
      platform = espressif32
      board = m5stack-cores3
      framework = arduino
      lib_deps =
        m5stack/M5Unified@0.2.3
        felmue @Girgitt
        Hello @Girgitt
        have you tried (as a test) to simply set the UART TX GPIO high or low?
        Could it be a contacts issue? Is the DIN Base stacked securely?
        • G
          Girgitt @felmue
          @felmue I tried different pins order, CoreS3 and Core2. Core2 works fine (UART on Port.C works) but CoreS3 gives no output on Port.C. I confirm each test result with a scope.
          The hardfware is stacked like this:
          [Core2/CoreS3]
          [stepmotor drivert v1.1]
          [din base]
            felmue @Girgitt
            Hello @Girgitt
            sorry if I wasn't clear. I meant a simple blink program like the one below. Does that work on your M5CoreS3?
            If not, have you tried (as a test) without the Stepmotor Driver module?
            #define TX_PIN GPIO_NUM_17
              pinMode(TX_PIN, OUTPUT);
              digitalWrite(TX_PIN, HIGH);
              delay(1000);
              digitalWrite(TX_PIN, LOW);
              delay(2000);
            • G
              Girgitt @felmue
              @felmue I get output on pin 18 only (Port.C RX pin), pin 17 is always at 3.2V.
              When I tap directly into the pin header on CoreS3 the PC_TX is at 3.2V.
              It must be a faulty CoreS3 then.
              Thanks for your help.
