    Need IR reader and writer with almost any controller
    17 Posts 4 Posters 11.1k Views 1 Watching
    • konacurrentsK Offline
      konacurrents @robski
      @robski I guess I haven't seen IR on my iPhone "mobile phone camera".
      So I'm looking for code that works, not a couple examples that aren't working for me (eg. the IR doesn't turn the TV on).
      Any production example would be nice.
      thanks,
      scott
        holofloh @konacurrents
        @konacurrents You wrote "I'm not using RC-5 with my ESP32 M5 controllers" and in the next posting "eg. the IR doesn't turn the TV on"
        So do you want to remote control a TV or another device? If you not using RC-5 what alternative protocol does your device use?
        For the mentioned test by the mobile phone camera: Test if ANY working remote from TV or HiFi etc... is visible by your mobile phone camera. Point the transmitter to the camera and press a button. If you see a flashing light, then your camera is able to see the IR light.
        Now do the same at the M5StickCPlus when one of the examples is running.
        If there is no flashing IR then investigate on the port number of the IRLED on your device and change it in the code to the right one. If it flashes but your receiving device is not reacting to it, it may be a wrong protocol or command.
        It may help if you post the code you are trying and a description of what exactly you want to control.
        konacurrentsK 1 Reply Last reply Reply Quote 0
        • robskiR Offline
          robski
          what is the code that isn't working for you and what devices are you using with it? I can take M5Stick with M5 IR module connected via groove port and it works fine
            konacurrents @holofloh
            @holofloh Using the latest iPhone I cannot see anything on the camera when pressing an IR transmitter. So I don't see that feature.
            I still don't know what RC-5 is in the M5 Stack of capabilities. All I have are M5 controllers.
            @robski said in Need IR reader and writer with almost any controller:
            M5 IR module
            Can you provide the IR Model? I'm using the Infrared Reflective Sensor (https://shop.m5stack.com/products/infrared-reflective-sensor-unit).
            The sample code is one of
            From device
            or
            IR Reflective via GROVE
            So any examples that work would be helpful. Every time I run them they never detect anything.
            thanks,
            • robskiR Offline
              robski @konacurrents
              @konacurrents said in Need IR reader and writer with almost any controller:
              You won't detect any logic (coded) IR signals from TV or audio remote controllers with this unit
              ie It is to detect "brake" of IR signal when object travels on production line etc
              for play with audio/tv remote controllers which are sending coded signals for each button press you need something like this:
              IR Emitter/Reciver
                @robski thanks, I'll order that part and hope it solves my challenge.
                  konacurrents @konacurrents
                  @konacurrents thanks, I've ordered that part and hope it solves my challenge. (I thought I had all the IR and RF controls, but that one slipped through.)
                  I assume the code will let me receive the code from buttons on a TV remote control, which I could then send from the M5 device later.
                  Thanks,
                    @konacurrents I also just found this IR library that I'll look at:
                    https://github.com/crankyoldgit/IRremoteESP8266
                      @konacurrents I have the IR Remote sensor, and I can now receive IR signals.
                      Cannot send IR
                      But I cannot send any IR signals (just repeating what was received). This is the volume on 3 or my remotes. I'm using the M5Atom button (which is Button B) to make do the IRSend command.
                      I found the IRremote and IRSender objects. I'm also using the Port B of my I2S using pins 33 and 32.
                      I'm trying to send what was printed from receiving the IR:
                      Send with: IrSender.sendSamsung(0x7, 0x7, <numberOfRepeats>);
                      By calling:
                          IrSender.sendSamsung(0x7, 0x7, 1);
                      Any ideas?
                      My sample program is below:
                        Please connect to Port B,Use IR Unit to receive and test infrared receiving
                        and transmitting 请连接端口B,使用红外单元接收和测试红外接收和发射.
                      #include <Arduino.h>
                      //#include <M5Core2.h>
                      #include <M5StickCPlus.h>
                      #include <IRremote.hpp>
                      #include <IRSend.hpp>
                      // I2S (middle port on Atom's port extender I2s driver)
                      int ir_recv_pin = 33;  // set the input pin.  设置引脚
                      int ir_send_pin = 32;
                      #define DELAY_AFTER_SEND 2000
                      #define DELAY_AFTER_LOOP 500
                      //!see https://forum.arduino.cc/t/irremote-sending-samsung-code-but-not-working/1312154
                      #define IR_RECEIVE_PIN ir_recv_pin
                      #define IR_SEND_PIN    ir_send_pin
                        Serial.begin(115200);
                        Serial.println();
                        IrReceiver.begin(IR_RECEIVE_PIN, ENABLE_LED_FEEDBACK);
                        delay(DELAY_AFTER_LOOP);
                        IrSender.begin(IR_SEND_PIN);
                        Serial.print(F("Ready to receive IR signals of protocols: "));
                        printActiveIRProtocols(&Serial);
                        //Serial.println(F("at pin " STR(IR_RECEIVE_PIN));
                        //Serial.println("loop");
                        M5.update();  // Read the press state of the key.  读取按键 A, B, C 的状态
                        if (M5.BtnA.wasReleased())
                          // If the button A is pressed.  如果按键 A 被按下
                          Serial.println("A");
                        else if (M5.BtnB.wasReleased())
                          // If the button B is pressed. 如果按键
                          // B 被按下,
                          Serial.println("B");
                          //! seems to be the main button.. B
                          //! lets send the volume UP
                          //Protocol=Samsung Address=0x7 Command=0x7 Repeat gap=46750us Raw-Data=0xF8070707 32 bits LSB first
                          Serial.println("IrSender.sendSamsung(0x7, 0x7, 1)");
                          IrReceiver.restartAfterSend(); // Is a NOP if sending does not require a timer.
                          delay(DELAY_AFTER_SEND);
                        else if (M5.BtnB.wasReleasefor(700))
                          // The button B is pressed for 700ms. 按键 B 按下
                          // 700ms,屏幕清空
                          Serial.println("b 700");
                           Check if received data is available and if yes, try to decode it.
                           Decoded result is in the IrReceiver.decodedIRData structure.
                           E.g. command is in IrReceiver.decodedIRData.command
                           address is in command is in IrReceiver.decodedIRData.address
                           and up to 32 bit raw data in IrReceiver.decodedIRData.decodedRawData
                        if (IrReceiver.decode()) {
                             Print a summary of received data
                          if (IrReceiver.decodedIRData.protocol == UNKNOWN) {
                            Serial.println(F("Received noise or an unknown (or not yet enabled) protocol"));
                            // We have an unknown protocol here, print extended info
                            IrReceiver.printIRResultRawFormatted(&Serial, true);
                            IrReceiver.resume(); // Do it here, to preserve raw data for printing with printIRResultRawFormatted()
                          } else {
                            IrReceiver.resume(); // Early enable receiving of the next IR frame
                            IrReceiver.printIRResultShort(&Serial);
                            IrReceiver.printIRSendUsage(&Serial);
                          Serial.println();
                        felmue @konacurrents
                        Hello @konacurrents
                        by Atom's port extender do you mean M5AtomABC? If yes, the middle port is using GPIO33 and GPIO23 (not GPIO32) - see here.
                          konacurrents @felmue
                          @felmue Wow, I'll be. I can get this to send now. Pin 23 was the key.
                          I thought I tried that. But then I looked at the image and it showed 32 (but now I realized I read it backward:-)
                          actually worse: I misread that the numbers instead of right to left, I used top/bottom or bottom/top (the 33 threw my pattern off) - and I had seen the GPIO link you sent.
                          So I'm on my way. Thanks so much.
                          Is there a process on how to repeat these calls to the various remote messages?
                          eg. I'm testing and it's sendNEC vs sendSamsung. How would a universal remote know this just from scanning (learning)?
                            Hello @konacurrents
                            yes, that silk screen can be a bit misleading.
                            There is function IrReceiver.getProtocolString() which gives you the protocol (e.g. NEC, Samsun, etc.) to use when sending a learned code. Have you tried that?
                              @felmue It looks like I need the binary version of getProtocolString. It seems the following is needed for sending an IRData (the mirror of what was learned from receiving.)
                               * Interprets and sends a IRData structure.
                               * @param aIRSendData The values of protocol, address, command and repeat flag are taken for sending.
                               * @param aNumberOfRepeats Number of repeats to send after the initial data if data is no repeat.
                               * @return 1 if data sent, 0 if no data sent (i.e. for BANG_OLUFSEN, which is currently not supported here)
                              size_t IRsend::write(IRData *aIRSendData, int_fast8_t aNumberOfRepeats)
                              And I need a way to get the IrReceiver to provide the IRData information. So It seems this is in the decodedIRData from the IrReceiver.decode call.
                               * Main class for receiving IR signals
                              class IRrecv {
                              public:
                                  IRData decodedIRData;       // Decoded IR data for the application
                              I assume I save these values with the associated functions (volume up, change channel, etc). I see that a lot of those functions are defined for various known operations, but for now I will learn from the IR receiver.
                              Thanks for the help.
