    CoreS3 and COMX LoRaWAN868 v2.0
    4 Posts 2 Posters 2.3k Views
      mohammedalmusimie
      I'm trying to configure the CoreS3 with the COMX LoRaWAN868 v2.0 module, but I haven't been able to get them working at all. I've tried multiple codes without any luck. Unfortunately, I can't find any guides specifically for the CoreS3 and this LoRa module.
      Any help would be much appreciated!
      • kurikoK Offline
        kuriko @mohammedalmusimie
        @mohammedalmusimie
        Have you tried the example code on the document? Have you configured pins define and dip switch correctly?
          mohammedalmusimie @kuriko
          @kuriko Thank you for your reply
          yes I tried the examples but it looks like they are ment for m5core not coreS3. And I always change the dip switch according to the code.
          • kurikoK Offline
            @mohammedalmusimie
            have you adapted the codes to CoreS3?
