    AIN 4-20mA Is this correct?
    Units
    2.8k
    • K
      Kris
      • robskiR
        robski
        If your current sensor already has an external power supply, the jumper cap is connected as shown on the bottom
        If your current sensor does not have an external power supply, connect the jumper cap as shown on the top, and connect the interface of AIN4-20mA
        • K
          Kris @robski
          @robski Yes or not. This is a publicly available manual. It is unreadable to me. This circuit that I drew does not work correctly.
          • robskiR
            robski @Kris
            @Kris if your sensor needs power supply like you drew it then it has to be connected to 24/gnd pins of module , sensor to IN and then you need to use 3 jumper setup not the one marked red on your picture
            • F
              fkarner @Kris
              Hi @Kris
              From my point of view it should work. Some time ago, I connected the AIN module with a pressure sensor according to this scheme:
              Works well in my case.
              flori
              • K
                Kris @fkarner
                @fkarner Tak mam podłączone i odczyt wynosi ciągle zero
                robskiR 2 Replies Last reply Reply Quote 0
                • robskiR
                  robski @Kris
                  @Kris what you see on multimeter (mA) in place of AIN module? Any values in range of 4-20mA?
                  • robskiR
                    robski @Kris
                    @Kris said in AIN 4-20mA Is this correct?:
                    this works for me:
