    Problems with M5GFX Library
    2 Posts 2 Posters 2.1k Views
    • 0 Offline
      007jimmey
      I been trying to get a M5-Stack 6-DoF IMU Pro Mini Unit (BMI270, BMM150, BMP280) to work for a project however I been having problem with getting the library to work.
      When I tried to run the example code from GitHub; Example code. I got this error even though I installed all the library's needed. I also re-installed/ updated Arduino IDE.
      Any other way I could do this would be welcome.
      In file included from C:\Users\28355\OneDrive - 28355\Documents\Arduino\libraries\M5GFX\src/M5GFX.h:19:0,
                       from C:\Users\28355\OneDrive - 28355\Documents\Arduino\libraries\M5Unified\src/M5Unified.hpp:19,
                       from C:\Users\28355\OneDrive – 28355\Documents\Arduino\libraries\M5Unified\src/M5Unified.h:5,
                       from C:\Users\28355\AppData\Local\Temp\.arduinoIDE-unsaved2025226-37800-1pdxwpq.agmb\sketch_mar26a\sketch_mar26a.ino:23:
      C:\Users\28355\OneDrive - 28355\Documents\Arduino\libraries\M5GFX\src/lgfx/v1/platforms/device.hpp:94:10: fatal error: arduino_default/Bus_SPI.hpp: No such file or directory
       #include "arduino_default/Bus_SPI.hpp"
      compilation terminated.
      exit status 1
      V 1 Reply Last reply Reply Quote 1
      • V Offline
        VashJuan @007jimmey
        @007jimmey Any update or resolution? Im encountering this on ArduinoDroid...
