    Solderless screw terminal proto base
    2 Posts 2 Posters 5.7k Views 1 Watching
      rob.biernat
      Hi
      Has anyone got something that exposes the gpio pins as a screw terminal for more permanent solderless connection?
      I'm going to surface mount my m5stack into a box so you wont see the bottom of it.
      Rob
        franzhoepfinger @rob.biernat
        @rob-biernat you can just make a Flat PCB, bigger than the M5 Stack,
        and place Terminals there.
        similar as it is done https://shop.m5stack.com/products/iot-learning-kit
