    Core Basic v2.7 not shown in IDE
    10 Posts 2 Posters 6.7k Views
      pleister
      I hava a Core Basic v2.7 with UIFlow v1.14.2 installed on it and set to USB mode. The "CH9102_VCP_SER_Windows" drivers are shown under Windows 11 and the device is recognized when plugged in.
      But when I try to conect with the MU IDE or VS Code no device is detected. I have tried it on 3 separate devices and run in the sam problem. The same issue with my Stick C Plus 2.
      Any one an idea what I am doing wrong?
      Cheers Philipp
      • robskiR Offline
        robski
        is it detected by M5Burner or/and Arduino?
          pleister @robski
          @robski yes Burner is dedecting it and I can burn the software on it. This is why I don't understand the problem.
          • robskiR Offline
            robski @pleister
            @pleister M5Stack devices added to VSCode?
              pleister @robski
              @robski it is not showing in VS Code. First I thougt that it was a problem of VS Code, that is why I tried it with MU.
              • robskiR Offline
                robski @pleister
                @pleister uninstall and install M5Stack extension maybe?
                  pleister @robski
                  @robski did that, same problem. I tried it on a new installed windows with a new USB-cable with the same outcome. Do I miss something
                  1. Install diver
                  2. Burn device
                  3. Install VS code with vscode-m5stack-mpy extension
                    than it should work right?
                  • robskiR Offline
                    robski @pleister
                    @pleister if M5Burner, Arduino, Uiflow2 are happy with your contoroller then cable is ok, driver is ok..
                    ..something isn't right with VS Code config
                      pleister @robski
                      @robski but what can I configure in VS Code, I dont see anything to set up?
                        pleister @pleister
                        @pleister found the solution in rebuilding the extension https://github.com/curdeveryday/vscode-m5stack-mpy/issues/45
