    4-20 mA Unit with wemos S2 mini ESP32
    Modules
    7.5k
    • O
      obstbauer @robski
      @robski ok I think I found it:
      thank you I will try tomorrow
      • robskiR
        robski @obstbauer
        @obstbauer yeah thats the registers table, I used Uiflow2 with calibration block but you are using not M5Stack controller I see
        • O
          obstbauer @robski
          @robski what value do you take for "index" in the function
          void MODULE_4_20MA::setCalCurrent(uint8_t index, uint16_t value)
          • robskiR
            robski @obstbauer
            @obstbauer haven't used index value
            in uiflow2 ..ain4_20ma_0.set_cal_current(10) to set 10mA
            ain4_20ma_0.set_cal_current(20) to set 20mA
            • O
              obstbauer @robski
              @robski yes maybe in uiflow2 but the function for the c program asks for an index and a value
              • O
                obstbauer @obstbauer
                I see really strange behaviour and I don't know the reason and I get no answers from the support.....
                The example code from M5Stack say that the currentvalue should be divided by 100:
                canvas.printf("Current:%.2fmA", (float)(meter.getCurrentValue(0)) / 100.0);
                The values I get I have to divide by 10 to get the right current in mA.... and the other issue is that I can only use half of the measurement range, at 12.5 mA the ADC sends 65520...
                maybe someone has an idea ?
                • O
                  change to a raspberry PI4 seems to be no solution too.....
                  it woud be nice if there would be a better documentation for people who want to use the units outside the m5stack universum....
                  • robskiR
                    robski @obstbauer
                    @obstbauer this is uiflow example with raw value and float too
                    • O
                      obstbauer
                      thank you, but I am still not able to read out or to set the cal current
                      M5Stack support doesn`t answer my mails... and it seems that there is nobody from the company around here, I think I will change to another board with better support
                      • robskiR
                        robski @obstbauer
                        @obstbauer TBH if you are using M5Stack modules/units with not M5Stack controllers maybe its worth to have at least one M5Controller (atom?stick? )to be able to check module functionality
