    m5stack tough for power monitoring suggestion
    PROJECTS
    4.3k
    • A
      aiconnection
      Hi
      I'm looking to monitor amp and voltage usage on a wire with a clamp type transformer sensor and M5stack tough device. I
      I have been trying to use SCT-013 20AMP/1V clamp sensor without any success. The configuration of the sensor is as per the attached figure sct013 wiring.jpg connecting it to the adc 36 pin and 3.3v supply and ground pins.
      But not having much of a luck.
      Is there any suggestion on the most cost effective and reliable method of monitoring 20 amps of power on a wire with minimal infrastructure, non invasive connection, using M5 stack tough device. I need specific suggestion on the use of clamp type sensor, code and wiring arrangements.
      robskiR 1 Reply Last reply Reply Quote 1
      • robskiR
        robski @aiconnection
        @aiconnection
        what type of load are you monitoring?
        • A
          aiconnection @robski
          @robski hi I have 20amp, 110v, 60hz load
          robskiR A 2 Replies Last reply Reply Quote 0
          • robskiR
            @aiconnection what is your code that doesn't work?
            • A
              aiconnection @aiconnection
              @aiconnection
              import M5
              from M5 import *
              from machine import ADC, Pin
              import time
              ADC_PIN = 35
              label_raw = None
              def setup():
              """Initialize the system."""
              global label_raw
              try:
              log("INFO", "Initializing system")
              M5.begin()
              Widgets.fillScreen(0xffffff) # White background
                  label_raw = Widgets.Label("Raw ADC:", 5, 40, 1.0, 0x000000, 0xffffff, Widgets.FONTS.DejaVu18)
                  adc = ADC(Pin(ADC_PIN))
                  adc.atten(ADC.ATTN_11DB)  # Set ADC range to 0-3.3V
                  adc.width(ADC.WIDTH_12BIT)  # Set 12-bit resolution
                  log("INFO", "System initialized successfully")
                  return adc
              except Exception as e:
                  log("ERROR", f"Setup failed: {str(e)}")
                  time.sleep(5)
                  reset()
              def log(level, message):
              """Log messages with a timestamp."""
              ts = time.localtime()
              print(f"[{level}][{ts[3]:02d}:{ts[4]:02d}:{ts[5]:02d}] {message}")
              def loop(adc):
              """Main loop to read and display raw ADC values."""
              try:
              while True:
              # Read raw ADC value
              raw_value = adc.read()
                      # Update display
                      label_raw.setText(f"Raw ADC: {raw_value}")
                      # Log raw value
                      log("DEBUG", f"Raw ADC: {raw_value}")
                      # Wait before next reading
                      time.sleep(5)
                  log("ERROR", f"Loop error: {str(e)}")
                  time.sleep(5)
                  reset()
              if name == 'main':
              try:
              # Initialize system and ADC
              adc = setup()
                  # Start the main loop
                  loop(adc)
                  log("ERROR", f"Fatal error: {str(e)}")
                  time.sleep(5)
                  reset()
              • A
                @robski good morning..any idea on the code please
                • robskiR
                  @aiconnection your initial post states " connecting it to the adc 36" then in the code posted later : "ADC_PIN = 35"
