M5Unit-8Encoder only for ESP32?
Hi, I got a M5Unit-8Encoder and I am trying to get it to work with a Arduino Nano Every and a RB Pi Pico. I installed the library on https://github.com/m5stack/M5Unit-8Encoder and have tried the example. However it throws many compiler errors. Digging deeper, I found that the library calls _wire->begin(_sda, _scl, _speed). So it passes three arguments, where the standard TwoWire class only has begin() functions with zero or one argument. However I am quite a beginner so am pretty much stuck.
What am I missing here? Is the library only supposed to work for ESP32? There is little to no further documentation to be found.
@jmcdeg
Did you ever progress with this issue. I am trying to pair the 8Ch Encoder unit with an M5Dial and am getting no-where. Fairly sure like you its an I2C issue.Strangely I had no problem getting it to work on a bare bones ESP32 Dev Module on the default I2C pins. https://www.az-delivery.de/en/products/esp32-developmentboard
See Code Below for that working example.
Somewhat Ironic that when trying to pair it with one of their own Boards (M5Dial) it doesn't work out of the box. UIFlow2 works fine. I just cant for the life of me get the Arduino framework example they provide to work.// ========== SETUP & LOOP ========== // void setup() { Serial.begin(115200); sensor.begin(&Wire, ENCODER_ADDR, 21, 22, 100000UL); while (!Serial); // Wait for serial Serial.println("System Ready - Send 'enc all set zero' to reset encoders"); // Initialize to first state sensor.setAllLEDColor(0xff0000); // Start main LEDs RED }
/* * Sequential Non-Blocking LED Control for UNIT_8ENCODER * - Main LEDs complete full cycle first * - Then Channel 0 LED runs its cycle * - Continues in this sequential pattern */ #include "UNIT_8ENCODER.h" UNIT_8ENCODER sensor; // ========== TIMING CONTROL ========== // unsigned long prevLedUpdate = 0; unsigned long prevEncoderReport = 0; const long LED_UPDATE_INTERVAL = 1000; // 1 second per color for main LEDs const long CH0_LED_INTERVAL = 250; // 250ms per color for channel 0 const long ENCODER_REPORT_INTERVAL = 2000; // Report every 2 seconds // ========== SYSTEM STATE ========== // enum SystemMode { RUNNING_MAIN_LEDS, RUNNING_CH0_LED }; SystemMode currentMode = RUNNING_MAIN_LEDS; // ========== LED STATE MACHINES ========== // enum MainLedState { MAIN_RED, MAIN_GREEN, MAIN_BLUE, MAIN_OFF, MAIN_COMPLETE }; MainLedState mainLedState = MAIN_RED; enum Ch0LedState { CH0_RED, CH0_GREEN, CH0_BLUE, CH0_OFF, CH0_COMPLETE }; Ch0LedState ch0LedState = CH0_RED; // ========== ENCODER FUNCTIONS ========== // void show_encoder_values() { Serial.println("\n----- Encoder Report -----"); for (int i = 0; i < 8; i++) { Serial.printf("Encoder CH-%d: %ld\n", i, sensor.getEncoderValue(i)); Serial.printf("Button CH-%d: %d\n", i, sensor.getButtonStatus(i)); } Serial.printf("Switch: %s\n", sensor.getSwitchStatus() ? "ON" : "OFF"); } void Zero_All_Encoders() { for (int i = 0; i < 8; i++) { sensor.resetCounter(i); } Serial.println("All encoders zeroed!"); } // ========== SEQUENTIAL LED CONTROL ========== // void update_leds_sequentially() { unsigned long currentMillis = millis(); switch(currentMode) { case RUNNING_MAIN_LEDS: if (currentMillis - prevLedUpdate >= LED_UPDATE_INTERVAL) { prevLedUpdate = currentMillis; switch(mainLedState) { case MAIN_RED: sensor.setAllLEDColor(0xff0000); // RED mainLedState = MAIN_GREEN; break; case MAIN_GREEN: sensor.setAllLEDColor(0x00ff00); // GREEN mainLedState = MAIN_BLUE; break; case MAIN_BLUE: sensor.setAllLEDColor(0x0000ff); // BLUE mainLedState = MAIN_OFF; break; case MAIN_OFF: sensor.setAllLEDColor(0x000000); // OFF mainLedState = MAIN_COMPLETE; break; case MAIN_COMPLETE: // Main cycle complete, switch to channel 0 currentMode = RUNNING_CH0_LED; ch0LedState = CH0_RED; // Reset channel 0 state prevLedUpdate = currentMillis; // Reset timer for channel 0 break; } } break; case RUNNING_CH0_LED: if (currentMillis - prevLedUpdate >= CH0_LED_INTERVAL) { prevLedUpdate = currentMillis; switch(ch0LedState) { case CH0_RED: sensor.setLEDColor(0, 0xff0000); // RED ch0LedState = CH0_GREEN; break; case CH0_GREEN: sensor.setLEDColor(0, 0x00ff00); // GREEN ch0LedState = CH0_BLUE; break; case CH0_BLUE: sensor.setLEDColor(0, 0x0000ff); // BLUE ch0LedState = CH0_OFF; break; case CH0_OFF: sensor.setLEDColor(0, 0x000000); // OFF ch0LedState = CH0_COMPLETE; break; case CH0_COMPLETE: // Channel 0 cycle complete, switch back to main LEDs currentMode = RUNNING_MAIN_LEDS; mainLedState = MAIN_RED; // Reset main LED state prevLedUpdate = currentMillis; // Reset timer for main LEDs break; } } break; } } // ========== SETUP & LOOP ========== // void setup() { Serial.begin(115200); sensor.begin(&Wire, ENCODER_ADDR, 21, 22, 100000UL); while (!Serial); // Wait for serial Serial.println("System Ready - Send 'enc all set zero' to reset encoders"); // Initialize to first state sensor.setAllLEDColor(0xff0000); // Start main LEDs RED } void loop() { // Handle serial commands if (Serial.available() > 0) { String input = Serial.readStringUntil('\n'); input.trim(); input.toLowerCase(); if (input == "enc all set zero") { Zero_All_Encoders(); } else { Serial.println("Unknown command. Try: 'enc all set zero'"); } } // Update LEDs sequentially update_leds_sequentially(); // Periodic encoder reports if (millis() - prevEncoderReport >= ENCODER_REPORT_INTERVAL) { prevEncoderReport = millis(); show_encoder_values(); } }
