"Disconnected from Serial Port" while running Hello World on M5Stack (UIFlow2, Ubuntu)
 Issue SummaryI'm trying to run a simple "Hello World" program on my M5Stack Core using UIFlow2 on Ubuntu 22.04, but I keep experiencing an issue where the serial connection drops unexpectedly. Here’s what happens when clicking Run or Download the program to the device: a pop up appears, the device connects successfully and logs RAM information: heap RAM free: 55760 heap RAM alloc: 45296 heap RAM free: 55760 heap RAM alloc: 45296 ...After a few seconds, I get "Disconnected from Serial Port", and the device is no longer accessible.My device shows Public, the device mac, the associated user account, a QR Code ... What I've Tried So Far - Checked USB connection
 - Used a high-quality data USB cable.
- Switched between USB 2.0 and USB 3.0 ports.
- Tried a different cable and another PC.
 - Verified Serial Port availability
 After disconnection, I ran ls /dev/ttyACM*Before and After disconnection: /dev/ttyACM0is listed. I can't see if it disconnects when I upload the code- Disabled ModemManager (Ubuntu)
 sudo systemctl stop ModemManager- Flashed the latest UIFlow2 firmware using M5Burner
 - Used M5Burner to install the latest version of UIFlow2.
- Issue persists even after flashing and rebooting.
 - Tried a minimal script in UIFlow2
 from m5stack import * from m5ui import * from uiflow import * lcd.clear() lcd.print("Hello World", 10, 10)The screen does not display "Hello World" before disconnection occurs. Questions - Why does my M5Stack disconnect from the serial port after a few seconds?
- Is this a firmware issue or a hardware problem?
- Could this be related to power management settings or a driver issue on Linux?
 Any help would be greatly appreciated! Thanks in advance. 😊
 Hi. I have the same problem. My Mint Linux pops up the terminal; says it connected; says it disconnected. Have you made any progress solving this problem?
 Yup, same. Got my M5Stack Basic 2.7 today, burned UIFlow2, but when I try to open a console, or run a program, it shows some log about connecting and disconnecting, and does nothing: Connected to Serial Port! 4592 heap RAM free: 86704 heap RAM alloc: 2heap RAM free: 86704 heap RAM alloc: 24592 heap RAM free: 86704 heap RAM alloc: 24592 heap RAM free: 86704 heap RAM alloc: 24592 heap RAM free: 86704 heap RAM alloc: 24592 heap RAM free: 86704 heap RAM alloc: 24592 heap RAM free: 86704 heap RAM 4592 heap RAM free: 86704 heap RAM alloc: 24592 Disconnected from Serial Port
 @Zverik
 have you flashed the correct firmware?
 @kuriko Of course, I've used M5Burner with the latest UIFlow2, as per the documentation. Just tried with the updated 2.2.7 version, still nothing.
 @Zverik
 that's a bit of weird, i think you should try flash the factory firmware to test out if that was a hardware failure
