    ADUINO compile error core2
    Modules
    4.0k
    • V
      VK3AWA_1
      Hi all,
      When I try and compile my Core 2 in Arduino IDE I get this error #include <rom/miniz.h> error.
      How can I rectify?
      Thanks DARYL - Paradise Beach Australia
      • kurikoK
        kuriko @VK3AWA_1
        @VK3AWA_1
        have you tried compile example programs? are you able to post your codes?
        V 1 Reply Last reply Reply Quote 0
        • V
          VK3AWA_1 @kuriko
          @kuriko
          Thanks for the reply. Yes I have since discovered that the M5Core2 examples cause the errors but the M5Unified examples work OK.
          CHEERS DARYL
          kurikoK 1 Reply Last reply Reply Quote 1
          • kurikoK
            kuriko @VK3AWA_1
            @VK3AWA_1
            1. If you are using Windows 10, upgrade your Windows system to the latest version.
            2. Use other operating systems to compile (such as Linux distributions).
            3. First, make sure that "rom\miniz.h" exists in Arduino's ESP32 board manager files. Then try to manually change all paths containing #include <rom/miniz.h> to absolute paths. For example, #include "C:\Users\admin\Documents\Arduino\libraries\esp32-xxx\xxxxxx\rom\miniz.h"
            • T
              thomasnagtegaal40
              Same issue here, with the M5Stack Core 1. Just installed all the packages / libraries following the M5Stack instructions.
              #include <M5Stack.h>
                // put your setup code here, to run once:
                M5.lcd.print("Hello World!");
                // put your main code here, to run repeatedly:
              Output:
              c:\Arduino\libraries\M5Stack\src\utility\pngle.c:31:10: fatal error: rom/miniz.h: No such file or directory
                 31 | #include <rom/miniz.h>
              compilation terminated.
              exit status 1
