    Title (English): Fixing M5Burner on macOS (Apple Silicon) - Manual Patch + Instructions Título (Español): Solución para M5Burner en macOS (Apple Silicon) - Parche manual + Instrucciones
    FAQS
    1.5k
    • nmstackN
      nmstack
      ENGLISH INSTRUCTIONS
      If M5Burner doesn't work on your new Mac (especially with macOS 15.x or Apple Silicon M4/M3), and it crashes on startup or doesn't load any firmware, here's how to fix it manually.
      🔄 Symptom
      M5Burner launches but shows errors like invalid signature: 0x54454d3c
      Missing folders like firmware/ or dat/ inside the app
      JavaScript or unzipper errors in Terminal
      🔧 Manual Fix Steps
      Download M5Burner (latest version)From the official site:https://m5stack.com/pages/download
      Fix permissions (required for macOS Gatekeeper)
      xattr -c /Applications/M5Burner.app
      Download the manual patch (missing folders)GitHub repo:https://github.com/neusmstack/M5Burner_patch
      Or direct download of the ZIP file:https://github.com/neusmstack/M5Burner_patch/raw/main/M5Burner_patch_files.zip
      Unzip the file and copy the firmware/ and dat/ folders into this path:
      /Applications/M5Burner.app/Contents/Resources/packages/
      Launch M5Burner again and everything should work fine:
      Firmware list will appear
      You can burn and configure devices
      🇪🇸 INSTRUCCIONES EN ESPAÑOL
      Si M5Burner no funciona correctamente en tu nuevo Mac (especialmente con macOS 15.x o Apple Silicon M4/M3), y se bloquea al arrancar o no carga firmwares, aquí tienes la solución manual.
      🔄 Síntomas
      M5Burner se inicia pero da errores como invalid signature: 0x54454d3c
      No aparecen las carpetas firmware/ o dat/ en la app
      Aparecen errores JavaScript en el Terminal
      🔧 Pasos para arreglarlo manualmente
      Descarga la última versión de M5BurnerDesde la web oficial:https://m5stack.com/pages/download
      Corrige los permisos de seguridad (Gatekeeper)
      Descarga el parche manual (carpetas faltantes)Repositorio GitHub:https://github.com/neusmstack/M5Burner_patch
      O descarga directa del archivo ZIP:https://github.com/neusmstack/M5Burner_patch/raw/main/M5Burner_patch_files.zip
      Descomprime el archivo y copia las carpetas firmware/ y dat/ dentro de esta ruta:
      Vuelve a abrir M5Burner y todo debería funcionar correctamente:
      Aparece la lista de firmware
      Puedes grabar y configurar tus dispositivos
      If this worked for you, please leave a like or comment in the forum to help others! 😊Si esto te funcionó, deja un like o comentario en el foro para ayudar a otros. 😊
      Neus Morlà
