    M5Stamp-Pico Solid Blue Light
    UIFlow
    1.8k
      marnix201
      Hi all,
      I have a problem with a M5Stamp Pico.
      When I power it up it successfully connects to the internet (with the provided credentials in M5Burner) but after that the LED stays SOLID Blue no matter what I'll do, so it will never get to the "Flashing green" status. (I uploaded the latest UIflow Firmware) (Not UIFlow 2.0 but just UIFlow 1)
      I tried reflashing it a couple of times, connect to different routers, tried different firmwares, I even tried other M5Stamp-Pico's, but I have the exact same problem with all of them. (They are all of the same 5 pack I ordered recently)
      Could it be a server problem or something ?
      Thanks,
      Marnix.
        felmue @marnix201
        Hello @marnix201
        I can confirm there seems to be an issue with UIFlow1 firmware for M5StampPico as I get the same result: solid blue light.
        I also tested with M5AtomLite / UIFlow1: same issue - blue light.
        However when I use an M5StackCore it connects ok to UIFlow1.
        Note: above tested with UIFlow1 firmware 1.14.5
        BTW: Any reason you are using UIFlow1? I tried M5StampPico with UIFlow2 and that worked for me.
          marnix201 @felmue
          Thank you for testing.
          I used lots of M5StampPico's and never had this issue before...
          Do you think it will be fixed any soon ?
          I especially avoid using UIflow 2 because unfortunately a lot of functions are still missing...
          I would like to use the remote+ funtion and/or Blynk but both of these are not available for UIFlow 2...
          So for now I guess I'm stuck on using UIFlow 1..
          • kurikoK
            kuriko @marnix201
            @marnix201
            The blue LED indicates that it is currently working in USB mode or is not connected to the server
              felmue @kuriko
              Hello @kuriko
              thank you for this information. I just retried M5StampPico with UIFlow1 and changed the Start Mode to USB Mode and back to Internet Mode. In both cases I get the blue light. So I guess it's not connected to the server.
                marnix201 @felmue
                Any updates on this @m5stack ?, does anyone know when this will be working again?
                Thanks,
                Marnix
                  marnix201 @marnix201
                  @m5stack still nothing ???...
                  I still can't connect with M5stamp-Pico and UIFlow 1, still have a solid blue light.
                  This used to be working fine in the past...
                  @felmue Any ideas on this ?
