    ⚠️ HELP: LVGL on M5Stack CoreS3 not detecting touch events ⚠️
    2 Posts 2 Posters 1.4k Views
      Robertof
      Hello community,
      I'm trying to integrate LVGL 9.3.0 with the touch screen on M5Stack CoreS3, but I'm facing an issue: touch events are not being registered correctly in LVGL, even though the touch screen works fine when tested using M5Stack's official example code.
      📌 Software versions I'm using: ✅ M5Stack CoreS3 (ESP32-S3-based hardware) ✅ LVGL version: 9.3.0 ✅ M5Unified library version: Latest available version (checked via Arduino IDE) ✅ LovyanGFX library version: Latest available version ✅ Arduino IDE version: 1.8.19 ✅ ESP32 Board Support Package: Latest version installed via Board Manager
      📌 What I’ve tested so far: ✅ The touch screen works correctly using CoreS3.Touch.getDetail(). ✅ LVGL is not detecting touches, suggesting a possible misconfiguration in lv_indev_t. ✅ I've implemented synchronization with CoreS3.update(), but LVGL still does not process touch events.
      📜 Current code I'm using:
      #include <M5CoreS3.h>
      #include <lvgl.h>
      // 🛠 Screen instance
      M5GFX display;
      // 🛠 Callback function for display update in LVGL
      void flush_cb(lv_display_t *disp_drv, const lv_area_t *area, uint8_t *color_p) {
          display.pushImage(area->x1, area->y1, area->x2 - area->x1 + 1, area->y2 - area->y1 + 1, (uint16_t*)color_p);
          lv_display_flush_ready(disp_drv);
      // 🛠 Touch event handling using CoreS3 and advanced debugging
      void my_input_read(lv_indev_t *indev, lv_indev_data_t *data) {
          CoreS3.update();
          auto t = CoreS3.Touch.getDetail();
          data->point.x = t.x;
          data->point.y = t.y;
          Serial.print("📍 Touch state: "); Serial.println((int)t.state);
          Serial.print("📍 Coordinates → X: "); Serial.print(t.x);
          Serial.print(" Y: "); Serial.println(t.y);
          if (t.state == m5::touch_state_t::touch_begin || t.state == m5::touch_state_t::hold_begin || t.state == m5::touch_state_t::drag_begin) {
              data->state = LV_INDEV_STATE_PR;
              Serial.println("✅ LVGL has detected the touch!");
          } else {
              data->state = LV_INDEV_STATE_REL;
      // 🛠 Creating a test button in LVGL
      void create_button(lv_obj_t *parent) {
          lv_obj_t *btn = lv_btn_create(parent);
          lv_obj_set_size(btn, 100, 50);
          lv_obj_align(btn, LV_ALIGN_CENTER, 0, 0);
          lv_obj_t *label = lv_label_create(btn);
          lv_label_set_text(label, "Press");
          lv_obj_center(label);
          lv_obj_add_flag(btn, LV_OBJ_FLAG_CLICKABLE);
      // 🛠 System initial setup
          auto cfg = M5.config();
          CoreS3.begin(cfg);
          Serial.begin(115200);
          Serial.println("\n🚀 M5Stack CoreS3 initialized with LVGL 9.3.0 🚀\n");
          display.init();
          lv_init();
          display.begin();
          display.setColorDepth(16);
          static lv_display_t *disp_drv = lv_display_create(320, 240);
          lv_display_set_flush_cb(disp_drv, flush_cb);
          // 🚀 Dynamic memory allocation to optimize RAM usage
          static lv_color_t *buf1 = (lv_color_t*)malloc(320 * 50 * sizeof(lv_color_t));
          if (buf1 == NULL) {
              Serial.println("❌ Error: Failed to allocate memory.");
              return;
          lv_display_set_buffers(disp_drv, buf1, NULL, 320 * 50 * sizeof(lv_color_t), LV_DISPLAY_RENDER_MODE_PARTIAL);
          // 🛠 Properly initialize the touch input handler in LVGL
          lv_indev_t *indev = lv_indev_create();
          lv_indev_set_type(indev, LV_INDEV_TYPE_POINTER);
          lv_indev_set_read_cb(indev, my_input_read);
          // 🛠 Create a test button in LVGL
          create_button(lv_scr_act());
          Serial.println("✅ LVGL initialized correctly, waiting for interaction...");
      // 🛠 Main loop for touch updates and LVGL handling
          CoreS3.update();
          lv_timer_handler();
          delay(5);
      💡 Has anyone successfully enabled touch detection in LVGL with M5Stack CoreS3? If you have any suggestions, insights, or working code examples, I’d really appreciate your help. 🙏
      Thanks in advance for any assistance! 🚀 Let’s get this working! 💪🔥
        andremp
