    Core S3 I2C Issue: SCL is held low on the bus
    4 Posts 2 Posters 3.4k Views 2 Watching
      terpasaurus
      Hi, I'm new to M5Stack. I have a Core S3, Unit CO2L, PaHub, and Unit LIGHT.
      Last week, I had a working setup for this in ESPHome. For some reason now, when I start the device it's unable to communicate over the Port A I2C bus assigned to GPIO pins 1 and 2. Whether I have the PaHub or the CO2L plugged directly into Port A, I get the following error about "SCL is held low on the bus."
      [07:19:11][C][i2c.idf:083]: I2C Bus:
      [07:19:11][C][i2c.idf:084]:   SDA Pin: GPIO2
      [07:19:11][C][i2c.idf:084]:   SCL Pin: GPIO1
      [07:19:11][C][i2c.idf:084]:   Frequency: 50000 Hz
      [07:19:11][C][i2c.idf:097]:   Recovery: failed, SCL is held low on the bus
      [07:19:11][I][i2c.idf:104]: Results from bus scan:
      [07:19:11][I][i2c.idf:106]: Found no devices
      [07:19:11][C][i2c.idf:084]:   SDA Pin: GPIO12
      [07:19:11][C][i2c.idf:084]:   SCL Pin: GPIO11
      [07:19:11][C][i2c.idf:094]:   Recovery: bus successfully recovered
      [07:19:11][I][i2c.idf:110]: Found device at address 0x34
      [07:19:11][I][i2c.idf:110]: Found device at address 0x40
      [07:19:11][I][i2c.idf:110]: Found device at address 0x51
      [07:19:11][I][i2c.idf:110]: Found device at address 0x58
      [07:19:11][I][i2c.idf:110]: Found device at address 0x69
      You can see here, I had two I2C bus configured, the internal sub on GPIO 11 and 12, and the external bus on GPIO 1 and 2:
      i2c:
        - id: i2c_port_a
          sda: GPIO2
          scl: GPIO1
          scan: true
        - id: i2c_internal
          sda: GPIO12
          scl: GPIO11
          scan: true
      sensor:
        - platform: scd4x
          i2c_id: i2c_port_a
          automatic_self_calibration: false
          co2:
            unit_of_measurement: "ppm"
            accuracy_decimals: 0
          temperature:
            unit_of_measurement: "°C"
            accuracy_decimals: 1
          humidity:
            unit_of_measurement: "%"
          update_interval: 5s
      I had a more complex configuration, but I have removed it down to the bare essentials after this issue began. I haven't done any soldering or even opened the device. Everything I find about this error has related to physical hardware issues folks typically caused while integrating custom hardware. But I haven't done anything like this.
      I have tried plugging in the PaHub and the CO2L and in both cases I see this issue. I have tried power cycling the device, etc.
        terpasaurus
        For the person who finds this later from a web search, I figured out an explanation. By default, the pins for the external I2C bus (GPIO1 and GPIO2) are not put into a usable power state. As the error message above states, the SDA pin has a low power signal being held which prevents other things from using this bus to communicate.
        The simplest way for me to ensure the pins (and other things) are initialized is to import the m5stack/M5Unified library from PlatformIO, and the external component board_m5cores3 from https://github.com/m5stack/M5CoreS3-Esphome, then declare board_m5cores3: in the ESPHome YAML config:
        esphome:
          friendly_name: ${friendlyname}
          platformio_options:
            board_build.flash_mode: dio
            board_build.mcu: esp32s3
            board_build.f_cpu: 240000000L
          libraries:
            - m5stack/M5Unified
        external_components:
          - source:
              type: git
              url: https://github.com/m5stack/M5CoreS3-Esphome
            refresh: 0s
            components: [board_m5cores3]
        board_m5cores3:
        This results in M5.begin() being called. The M5 namespace on which it's calling begin() is provided by the m5stack/M5Unified C++ library. This ensures physical buttons and hardware are initialized properly for this particular board.
        The begin method is defined here. On L349-343:
        auto board = _check_boardtype(Display.getBoard());
        if (board == board_t::board_unknown) { board = cfg.fallback_board; }
        _board = board;
        _setup_pinmap(board);
        _setup_i2c(board);
        That call _setup_i2c is calling this and this from deeper within the M5Unified's I2C library. That seems to cause SDA to not be held in LOW state.
          hacxx
          It sounds like the SCL line on GPIO1 is stuck low, causing the bus to hang. Since your internal I2C on GPIO11/12 works fine, this suggests a hardware issue on Port A or interference on those pins. Double-check for any accidental shorts, damaged cables, or faulty devices connected to Port A. Also, try disconnecting all devices from Port A and test again. If the problem persists, it might be a hardware fault on the Core S3 board’s GPIO1 pin. Consider testing with a different device or contacting M5Stack support for hardware diagnostics.
            terpasaurus @hacxx
            @hacxx I was able to work out the problem. I implemented changes to the m5stack board_m5cores3 component which makes it enable the correct AXP2101 power management for I2C for the Port A Grove port when using USB-C power.
            My issue was when using the device with the DIN base and the battery on and a sensor (CO2L) plugged into the Grove Port A (I2C), the device would be working. But if I disconnect USB-C from my computer and switch off the DIN base power, then switch the DIN base back on and plug USB-C back in (simulating a complete power outage of mains and battery) the device would boot loop with the message about SDA being held low.
            The only way for me to get out of the loop is to unplug the CO2L from Port A. Then the device would boot on its next attempt and the I2C port recovery would be successful. Finally, I could plugin the CO2L, reset using the button, and everything would work again.
            The issue was I needed to call M5.Power.setExtOutput during setup() of the BoardM5CoreS3 class from the https://github.com/m5stack/M5CoreS3-Esphome repo's components.
            void BoardM5CoreS3::setup() {
              ESP_LOGI(TAG, "Enabling 5V power output on the external ports");
              M5.Power.setExtOutput(true);
              ESP_LOGI(TAG, "Turning off display panel backlight");
              M5.Display.setBrightness(0);
            I implemented this in a custom component which I then add as an external_component to my ESPHome config. I added additional functionality in a separate component, to expose the AXP2101 battery level, charging status, etc. I also added an automation action to allow printing out debug state info from the AXP2101, to help with debugging the IRQ and other power management concerns.
            In my ESPHome config it looks like this now and the CO2L sensor works reliably now without the controller going into boot-loops from various power loss/power source change scenarios:
            esphome:
              platformio_options:
              libraries:
                - m5stack/M5Unified
              - source:
                  type: git
                  url: https://github.com/terpasaurus-midwest/esphome-fork
                  ref: m5cores3
                  path: my_components
                refresh: 2min
                components: [m5cores3_power, board_m5cores3]
            board_m5cores3:
            m5cores3_power:
              battery_sensor:
              battery_present_sensor:
              battery_charging_sensor:
                name: "Battery Charging"
