    Tensile test machine?
    UIFlow
    • K
      killernils
      Hi! I would like to get your assitance/assessment on a project :)
      Specifically if it is doable with UIflow2 or if I need to switch to micropython?
      I have:
      M5stack core s3
      M5stack Unit weight-I2C
      M5stack Stepmotor Driver Module 13.2 v1.1
      10kg load cell
      Step motor
      trapzodial rod T8x4.
      My aim is to build a small tensile test machine and plot displacement vs. load.
      Basically:
      *calibrate load cell with known weight.
      *Tare
      *Move load cell by stepper and count step(i.e displacement)
      *Poll load cell
      *Stop at a set max load
      *Save load vs disp in a csv-file
      *Reverse motor back to org position
      And a graphic on the display showing buttons for calibrate, tare and start.
      Best regards, H
      • Y
        yuyun2000 @killernils
        @killernils Your project is feasible with UIflow2 (MicroPython). Here's the breakdown:
        Hardware Compatibility:
        CoreS3 (SKU:K128) supports both Unit Weight-I2C and Module13.2 Stepmotor Driver v1.1 (SKU:M039-V11) via I2C
        Stepper driver provides precise control with microstepping (FULL to 1/32 step) and step counting
        Weight unit offers calibration, tare function, and filter settings through UIflow2 blocks
        Required Functions Implementation:
        Load Cell Calibration: Use WEIGHT_I2CUnit.set_calibration() with known weights
        Tare Function: Implement via WEIGHT_I2CUnit.set_reset_offset()
        Stepper Control: Utilize StepMotorDriverModule methods for direction, microstepping, and PWM frequency control
        Position Tracking: Count steps using motor control commands and convert to displacement based on T8x4 rod (4mm per revolution)
        Data Logging: Use UIflow2's file system blocks to save CSV data to internal storage
        HMI Interface: Create buttons and plots using CoreS3's display blocks
        Implementation Considerations:
        Ensure proper power supply (9-24V) for the stepper driver
        Implement step delay logic for smooth motor movement
        Add error handling for load cell over-range conditions
        Use filter functions on weight readings for stable measurements
        https://chat.m5stack.com/
