    M5Apps - multiple apps installer
    18 Posts 9 Posters 19.8k Views
      d4rkmen @d4rkmen
      @d4rkmen v1.2 comes with WiFi scan feature and more free flash space for apps.
      The Cloud repository:
      M5Burner for burner mirror in convenient way.
      TOP-20 for best apps tested by me
      • E Offline
        erwantest123
        hello i have a error with sha256 verification
        bye
        P.S. i love your project
        serial logs:
        [FROM M5Burner] COM3 opened.
        load:0x600fe100,len:0x1c
        SHA-256 comparison failed:
        Calculated: 5e23c97eab19023e851de85f4eeea87aed472ea13e871562b17f2a5ec097a9f5
        Expected: 1108a20e982d1031358092f5f1acb0437a206312e99d5443a1985793bd2c5984
        Attempting to boot anyway...
        entry 0x40375408
        ESP-ROM:esp32s3-20210327
        Build:Mar 27 2021
        rst:0x7 (TG0WDT_SYS_RST),boot:0x2b (SPI_FAST_FLASH_BOOT)
        Saved PC:0x40389f10
        SPIWP:0xee
        mode:DIO, clock div:1
        load:0x3c0f0020,len:0xc91a8
        load:0x3fc9a100,len:0x4ba8
        load:0x40374000,len:0x2298
        load:0x42000020,len:0xe5b9c
        load:0x40376298,len:0x13e40
        entry 0x40375408
        Build:Mar 27 2021
        Saved PC:0x403743c0
        SPIWP:0xee
        [FROM M5Burner] Serial Port Disconnected.
          d4rkmen @erwantest123
          @erwantest123 wow, first feedback :)
          thanks for this. whould be nice to have steps to reproduce
          • E Offline
            erwantest123
            hello 1.3 work for me
            thank you
              @erwantest123 was my fault. I have put single app file to M5Burner isntead of full fw :(
              Check for new TOP-20 updates:
              • Snake: classic game
              • M5Tuna: guitar tuner app
              Both apps are ~350Kb, could be used with M5Apps very well
                d4rkmen
                v1.5
                • Added version to boot animation
                • Cloud source error messages are now more informative
                • Minor UI fixes (hints, navigation, sound)
                • B Offline
                  bigchease
                  this might be a dumb question but is there any way to get a bin file for m5 launcher
                    d4rkmen @bigchease
                    @bigchease no, you have to flash full firmware (bootloader, PT, nvs, and the rest). Thans why you have to use some other flasher like M5Burner or esptools.
                      kermit17 @d4rkmen
                      @d4rkmen
                      Hi, are you talking about M5 Launcher project or something different?
                      I'm confused (new user) as the version numbers seem very different between what you say and what I see on M5 Burner.
                      PS is there any chance of something like this for Tab5?
                      • ImLunchtimeI Offline
                        ImLunchtime
                        Would this project ever be open-source? I was trying to create such a firmware manager for my Tab5 device and was encountering troubles, the M5Launcher's approach was strange (seems like it needs a custom bootloader which I don't have) so I wanted to check M5Apps out. It would be the best if M5Apps are open source.
                        • Y Offline
                          yehors
                          If this broke your cardputer here is how to fix it:
                          Before plugging your cardputer in hold the GO button and then plug in the cable. Cardputer will enter the download mode and you can then flash everything you want!
                          ~ yehor
                            troyler
                            is there a way to increase the storage to add more apps, i have 64gb.
                              d4rkmen
                              New version available on M5Burner
                              v1.9
                              • Added new app FINDER: two-panel file manager for SD card and USB drive
                              • Improved keyboard navigation in all apps
                              • Fixed keyboard sound issues
                              • INSTALLER: Added sorting files and folders by name
                              • INSTALLER: Cloud source fixed HTTP buffers
                              • FDISK: Added creation of new data partitions (press A)
                              • FDISK: No reboot required after deleting data partition
                              • Updated to the latest ESP-IDF v5.5.1
                              • Updated USB MSC driver
                                dzepetko
                                How can i install meshtastic and 4exampe winamp? - i have error not enough space.. ;/
                                  cricri
                                  Nice job !!! very interesting approch with no burning in between apps
                                  But memory is a real limit
                                  How to uninstall unused app from memory ?
                                    d4rkmen @cricri
                                    @cricri There is FDISK utility built-in.
                                    You can list all the partitions and delete those are not used anymore. System partitions are read-only, so you will not delete anything extra.
                                    Also you can create new partition at any time. For example, the Game Station requires spare partition for cache. so just add it in FDISK with a few clicks.
                                    @dzepetko said in M5Apps - multiple apps installer:
                                    By default the SDK (ESP-IDF) makes firmware bundle with default partitions, But the thing is: application could not use it at all or use one of them. So we can cook a binary with only partitions that really need by the app. This can save much space.
