    Unexpected behavior on M5stack fire LEDs
    Scheduled Pinned Locked Moved M5Stack Fire
    5 Posts 4 Posters 10.7k Views 1 Watching
    • B Offline
      bob1996w
      Hello, I have just got my M5stack fire and is making a simple LED modifying program with M5ez. I use the same library as samples in arduino IDE, Adafuit_NeoPixel. The program compiles with no errors, but when I start to use, the LEDs behave wierd.
      Here are the revalent code.
      #define M5_NEO_NUM 10
      #define M5_NEO_PIN 15
      Adafruit_NeoPixel pixels = Adafruit_NeoPixel(M5_NEO_NUM, M5_NEO_PIN);
        #include <themes/default.h>
        #include <themes/dark.h>
        ezt::setDebug(INFO);
        pixels.begin();
        pixels.setBrightness(255);
        pixels.show();
        ez.begin();
      Selecing which LED to control...
      void mainmenu_leds() {
        ezMenu submenu("Set LED colors");
        submenu.txtSmall();
        submenu.buttons("up # Back # Select # # down #");
        for(int i = 0; i < 10; ++ i) {
          submenu.addItem("LED#" + (String)i);
        submenu.upOnFirst("last|up");
        submenu.downOnLast("first|down");
        while (submenu.runOnce()) {
          int pickedItem = (int)submenu.pick() - 1;
          if (pickedItem >= 0 && pickedItem < 10) {
            menu_setLED(pickedItem);
      Each LED gets individual control options here. (0 <= led_no <= 9)
      void menu_setLED(int led_no) {
        ez.msgBox("Set LED#" + (String)led_no,
          "You have picked LED#" + (String)led_no);
        ezMenu submenu("Set LED#" + (String)led_no);
        submenu.txtSmall();
        //submenu.addItem("R | R\t0");
        //submenu.addItem("G | G\t0");
        //submenu.addItem("B | B\t0");
        submenu.addItem("black | Turn off");
        submenu.addItem("white | Turn bright");
        while(submenu.runOnce()) {
          if (submenu.pickName() == "black") {
            pixels.setPixelColor(led_no, pixels.Color(0, 0, 0));
            pixels.show();
            delay(20);
          else if (submenu.pickName() == "white") {
            pixels.setPixelColor(led_no, pixels.Color(255, 255, 255));
            pixels.show();
            delay(20);
      Expected behavior:
      When "black" is picked, the corresponding LED should be turned off (pixels.Color(0,0,0))
      When "white" is picked, the LED should turn white (pixels.Color(255,255,255))
      What really happens:
      Usually the corresponding LED behaves normally, but the other LED may also light up random color due to unknown reasons.
      Also, when set LED#0 to black, it displays green. That means LED#0 cannot be turned off now.
      I really don't know what is happening here, please help. Thanks in advance.
      m5-docsM ajb2k3A 2 Replies Last reply Reply Quote 0
      • m5-docsM Offline
        m5-docs @bob1996w
        @bob1996w
        Please use FastLED Library for controlling RGB Led instead of Adafuit_NeoPixel Library.
        https://github.com/FastLED/FastLED
        Because controlling RGB Led with Adafuit_NeoPixel Library will cause some unexpected bug, like some leds will turn into unexpected status(on or blink).
        M5Stack documentation URL
        https://docs.m5stack.com
          ajb2k3 @bob1996w
          @bob1996w said in Unexpected behavior on M5stack fire LEDs:
            pixels.begin();
            pixels.show();
            ez.begin();
            submenu.txtSmall();
            submenu.txtSmall();
                pixels.show();
                delay(20);
                pixels.show();
                delay(20);
          Expected behavior:
          The Neopixel code uses WS2812 leds where as the Go based used on the fire uses SK6812 leds which operate differently.
          • B Offline
            bob1996w
            Thanks for the replies! The FastLED works with no "ghost LEDs", but I still have some questions:
            When changing leds[some_led_index].r, it actually changes the green value of the led. leds[some_led_index].g changes red. blue works normally. Is there anyone having same problems? Thanks.
            This is the current settings I'm using:
            CRGB leds[M5_NEO_NUM];
            void setup()
              FastLED.addLeds<SK6812, M5_NEO_PIN>(leds, M5_NEO_NUM);
              // other setups...
            Compiler complains that No hardware SPI pins defined. All SPI access will default to bitbanged output, so I also tried WS2811, but the same problem continues.
            The revelant code:
            void setLedSingleChannelValue(int led_no, String channel, int val) {
              Serial.println("led_no " + (String)led_no + ", channel " + channel + ", val " + (String)val);
              if (channel == "R") {
                if (led_no < 10) {
                  leds[led_no].red = val;
                else {
                  if (led_no == 10 || led_no == 11) {
                    for (int i = 0; i < 5; ++ i) {
                      leds[i].red = val;
                  if (led_no == 10 || led_no == 12) {
                    for (int i = 5; i < 10; ++ i){
                      leds[i].red = val;
              else if (channel == "G") {
                if (led_no < 10) {
                  leds[led_no].g = val;
                else {
                      leds[i].g = val;
                      leds[i].g = val;
              else if (channel == "B") {
                if (led_no < 10) {
                  leds[led_no].b = val;
                else {
                      leds[i].b = val;
                      leds[i].b = val;
              FastLED.show();
              delay(5);
            void checkAndSetLedSingleChannel(int led_no, String channel, int delta) {
              int check_led_no = (led_no < 10) ? led_no : (led_no == 12) ? 9 : 0;
              int currentValue = getLedSingleChannelValue(check_led_no, channel);
              int afterValue = currentValue + delta;
              afterValue = (afterValue < 0) ? 0 : (afterValue > 255) ? 255 : afterValue;
              setLedSingleChannelValue(led_no, channel, afterValue);
            void menu_setLedSingleChannel(int led_no, String channel) {
              ezMenu submenu(getLedHeaderText(led_no, "Set"));
              submenu.txtSmall();
              submenu.buttons("-1 # -10 # Back | OK # # +1 # +10 # -50 # +50 # ");
              submenu.addItem(channel + " | " + channel + "\t" + (String)getLedSingleChannelValue(led_no, channel));
                String pickButton = submenu.pickButton();
                if (pickButton == "-1") {
                  checkAndSetLedSingleChannel(led_no, channel, -1);
                else if (pickButton == "+1") {
                  checkAndSetLedSingleChannel(led_no, channel, 1);
                else if (pickButton == "-10") {
                  checkAndSetLedSingleChannel(led_no, channel, -10);
                else if (pickButton == "+10") {
                  checkAndSetLedSingleChannel(led_no, channel, 10);
                else if (pickButton == "-50") {
                  checkAndSetLedSingleChannel(led_no, channel, -50);
                else if (pickButton == "+50") {
                  checkAndSetLedSingleChannel(led_no, channel, 50);
                submenu.setCaption(channel, channel + "\t" + (String)getLedSingleChannelValue(led_no, channel));
                delay(20);
            // The program enters from this function.
            void menu_setLed(int led_no) {
              submenu.txtSmall();
              submenu.addItem("R | R\t" + (String)getLedSingleChannelValue(led_no, "R"));
              submenu.addItem("G | G\t" + (String)getLedSingleChannelValue(led_no, "G"));
              submenu.addItem("B | B\t" + (String)getLedSingleChannelValue(led_no, "B"));
                String picked = submenu.pickName();
                if (picked == "black") {
                if (picked == "R" | picked == "G" || picked == "B") {
                  menu_setLedSingleChannel(led_no, picked);
                delay(20);
              horsley
              @bob1996w I meet the same problem, I think I can answer your last question about RGB. I found code on M5Stack_NeoPixelTest.ino
              #define M5STACK_FIRE_NEO_NUM_LEDS 10
              #define M5STACK_FIRE_NEO_DATA_PIN 15
              Adafruit_NeoPixel pixels = Adafruit_NeoPixel(M5STACK_FIRE_NEO_NUM_LEDS, M5STACK_FIRE_NEO_DATA_PIN, NEO_GRB + NEO_KHZ800);
              NEO_GRB was the data stream order flag according to the comment. GRB & RGB orders different!
              There were similar flags for FastLED, working code shows below
              FastLED.addLeds<WS2812B, M5STACK_FIRE_NEO_DATA_PIN, GRB>
