Issues with ESP now (Cardputer-Adv, UIFlow2.3.9)
Hi everyone!
having some problems with ESP now on the latest micro python UIFlow (2.3.9).
the simplest program I have is below, stripped right to the basics (just a loopback)
problem is the sends go through ok i.e. no exceptions but the receiver is not picking anything up.
I have tried a lot of things but no luck, any ideas would be greatly appreciated!
if anyone is running obvs change Mac address.
Thanks!!!
import network from m5espnow import * # Correct import for UIFlow firmware from m5espnow import M5ESPNow import time # Callback: Fires automatically on incoming messages def espnow_recv_callback(espnow_obj): sender_mac, data = espnow_obj.recv_data() # sender_mac is hex str, data is bytes if data is not None: try: msg_text = data.decode('utf-8') except: msg_text = repr(data) print(f"[RECEIVED from {sender_mac}] {msg_text}") # 1. WiFi setup (must be in this order for stability) wlan = network.WLAN(network.STA_IF) wlan.active(True) wlan.config(pm=0) # Disable power saving wlan.disconnect() # Force disconnect to free radio wlan.config(channel=11) # Fixed channel (try 6 or 11 if interference) time.sleep(0.5) # Settle time # 2. M5ESPNOW setup e = M5ESPNow(11) # Create instance (default wifi_ch=0) e.set_irq_callback(espnow_recv_callback) # Register callback e.active(True) # Activate ESP-NOW # 3. Get own MAC as hex string (no colons, lowercase) my_mac_bytes = wlan.config('mac') my_mac_hex = ''.join(f'{b:02x}' for b in my_mac_bytes) print("My MAC:", my_mac_hex) # 4. Add self as peer (peer_mac: str, peer_id: 1, ifidx: 0, encrypt: False) e.set_add_peer(my_mac_hex, 1, 0, False) print("=== Starting loopback test (watch for RECEIVED lines) ===") # 5. Send loop to self (peer_id=1) counter = 0 while counter < 5: counter += 1 msg = f"Hello from Cardputer! #{counter}".encode('utf-8') # Bytes payload success = e.send_data(1, msg) # Send to peer_id=1 (self) print(f"Sent #{counter} (success: {success})") time.sleep(2) # Wait for callback to fire
