    any known good yaml configs for esphome for the tab5 v2
    ESPHome
      manmade
      I'm looking for a working yaml to set up the tab5v2 for use with home assistant. So far it's taken me 5 hours to learn that I have a v2 tab5 and not the one that the demo uses. I have gotten it to boot, and it connects to the wifi, but I just get a blank screen with blacklight on. no telling if touch works or anything else.
      esphome:
        friendly_name: M5Stack Tab5 V2
        min_version: 2025.9.3
      esp32:
        board: esp32-p4-evboard
        flash_size: 16MB
        framework:
          type: esp-idf
          advanced:
            enable_idf_experimental_features: true
      external_components:
        - source: github://pr#12075
          components: [st7123]
          refresh: 0s
        - source: github://pr#12074
          components: [mipi_dsi]
          refresh: 0s
      # 2. WIFI CO-PROCESSOR
      esp32_hosted:
        variant: esp32c6
        active_high: true
        clk_pin: GPIO12
        cmd_pin: GPIO13
        d0_pin: GPIO11
        d1_pin: GPIO10
        d2_pin: GPIO9
        d3_pin: GPIO8
        reset_pin: GPIO15
        slot: 1
      logger:
        hardware_uart: USB_SERIAL_JTAG
      psram:
        mode: hex
        speed: 200MHz
      wifi:
        ssid: !secret wifi_ssid
        password: !secret wifi_password
      i2c:
        - id: bsp_bus
          sda: GPIO31
          scl: GPIO32
          frequency: 200kHz
          scan: true
      pi4ioe5v6408:
        - id: pi4ioe1
          address: 0x43
        - id: pi4ioe2
          address: 0x44
      switch:
         - platform: gpio
          pin:
            pi4ioe5v6408: pi4ioe2
            number: 0
          restore_mode: ALWAYS_ON
        - platform: gpio
          pin:
            number: 3
        - platform: gpio
          name: "External 5V Power"
          pin:
            pi4ioe5v6408: pi4ioe1
            number: 2
        - platform: gpio
          pin:
            number: 1
      # 4. TOUCHSCREEN (V2)
      touchscreen:
        - platform: st7123
          i2c_id: bsp_bus
          interrupt_pin: GPIO23
          display: lcd
          reset_pin:
            number: 5
      # 5. LDO & DISPLAY
      esp_ldo:
        - voltage: 1.1V
          channel: 4 # MIPI DSI Logic
        - voltage: 2.7V
          channel: 3 # Analog Power
      display:
        - platform: mipi_dsi
          pixel_mode: 24bit
          dimensions:
            height: 1280
            width: 720
          model: M5STACK-TAB5-V2
          reset_pin:
            number: 4
            inverted: true
      output:
        - platform: ledc
          pin: GPIO22
          frequency: 1000Hz
      light:
        - platform: monochromatic
          output: backlight_pwm
          name: "Display Backlight"
          restore_mode: RESTORE_DEFAULT_ON
          initial_state:
            brightness: "100%"
      font:
        - file: "gfonts://Roboto"
      lvgl:
        buffer_size: 10%
        displays:
          - lcd
        touchscreens:
          - touch
        # 1. DEFINE STYLES HERE (Global Level)
        style_definitions:
          - id: red_bg_style
            bg_color: 0xFF0000
            bg_opa: 100%
          - id: blue_btn_style
            bg_color: 0x0000FF
            bg_opa: 100%
            text_color: 0xFFFFFF
        # 2. USE STYLES HERE
        pages:
          - id: main_page
            # Apply the red background to the whole page
            styles:
              - red_bg_style
            widgets:
              - button:
                  align: center
                  width: 50%
                  height: 20%
                  text: "PRESS ME"
                  text_font: roboto_16
                  # Apply the blue style to the button
                  styles:
                    - blue_btn_style
                  on_click:
                    - logger.log: "TOUCH IS WORKING!"
      M easytargetE 2 Replies Last reply Reply Quote 0
        manmade @manmade
        @manmade nothing is shown on the screen still, however I have been able to add the device to home assistant and connect to the api to turn the backlight on and off.
        • easytargetE
          easytarget @manmade
          @manmade
          I dont see the nRESET signal being removed from the LCD, TouchPanel (and Camera).
          It's a low=active reset for these devices, and the E1 pi4ioe5v6408 chip that controls them will default these pins to low (actually, input-pulldown) and holds the reset pin active. These are pins 4,5,6 on the chip:
          Maybe you need something like:
            - platform: gpio
              pin:
                number: 4
            - platform: gpio
              pin:
                number: 5
            - platform: gpio
              pin:
                number: 6
          Because these are active-low lines they are being applied when the unit powers up, you have to explicitly remove them after boot.
          This is a guess, I'm not running HA on my tab5. There may be other things that need to happen too or are broken. But I just spent all day playing with some TAB5 hardware stuff in MicroPython and
          this was one of the things I discovered..
