    AtomS3U USB otg.
    atom s3
    2 Posts 1 Posters 922 Views
      Krist
      I have the AtomS3U, and have a key module that I can attach to it.
      I have been playing around with UIFlow2 to get a bit a feel of this thing, an managed to do things like change the led colour when the key is pressed, making the led cycle colors etc...
      What I however would like to do is have the AtomS3U emulate a keyboard. It supports usb OTG, so that should be supported. I want to try something simple first: Press the button and output some character to the connected PC.
      I have not found information on how to do this with UIFlow2. Would this need me diving in to micropython or arduino?
        Krist @Krist
        I tried the following code:
        import os, sys, io
        import M5
        from M5 import *
        from unit import KeyUnit
        from usb.device.keyboard import Keyboard
        from usb.device.hid import KeyCode
        keyboard = None
        key_0 = None
        def key_0_wasClicked_event(state):
          global keyboard, key_0
          keyboard.set_keys(KeyCode.A, 0, 0, 0, 0, 0)
        def setup():
          M5.begin()
          keyboard = Keyboard()
          key_0 = KeyUnit((1, 2))
          key_0.setCallback(type=key_0.CB_TYPE.WAS_CLICKED, cb=key_0_wasClicked_event)
        def loop():
          M5.update()
          key_0.tick(None)
        if __name__ == '__main__':
          try:
            setup()
            while True:
              loop()
            try:
              print_error_msg(e)
            except ImportError:
        And I got the following error:
          File "main.py", line 5, in <module>
        ImportError: no module named 'usb'
        So the usb module is not present in the firmware.
        • Is that on purpose, or is this a bug?
        • Is there a way to add the library?
