    Tab5 I2C on Arduino works, same code does not work on PlatformIO
    2 Posts 1 Posters 1.1k Views
      tonaug58
      Tab5 uses internally I2C for example for RTC and Battery-status. I can add I2C devices on the I2C port in this way:
      setup():
        // Start I2C
        if (!M5.Ex_I2C.begin(I2C_NUM_0, 31, 32)) {
      		Serial.println("Ex_I2C initialization failed!");
        } else {
          exI2CInitialized = true;
          Serial.println("Ex_I2C ok! ");
      In the modified I2C sensor code:
      uint8_t TON_BME280::read8(byte reg) {
      	return M5.Ex_I2C.readRegister8(BME280_ADDRESS, reg, 400000U);
      This works on Arduino, RTC (internal) and BME280 (external) are available.
      However, on PlatformIO same code, it does not work. The first call to battery status returns zeroes and subsequent I2C calls hang the system.
      Why use PlatformIO then? It compiles quicker, more control over libraries possible (lvgl 8 or 9 etc)
      Why use the same pins as internal for external I2C instead of two fresh ones?
      Modules like relays or stepper controllers all use the 31 and 32 pins for I2C
      platformio.ini:
      [env:m5stack-tab5-p4]
      platform = https://github.com/pioarduino/platform-espressif32/releases/download/stable/platform-espressif32.zip
      board = m5stack-tab5-p4
      framework = arduino
      upload_port = COM12
      monitor_port = COM12
      upload_speed = 1500000
      monitor_speed = 115200
      build_type = debug
      board_build.partitions = partitions.csv
      lib_deps =
        lvgl/lvgl@^8.3.11
        paulstoffregen/OneWire@^2.3.8
        milesburton/DallasTemperature@^4.0.5
        tonaug58
        Update on this one:
        Changing to other pins for external I2C makes it work for both Arduino and PlatformIO.
        So with arduino you can lay external I2C over the internal I2C, but in PlatformIO that does not work. Anybody an idea why not?
