    [RELEASE] WiFi CSI Radar ADV (V1.42) - Detect Motion Through Walls with Cardputer!
    1 Posts 1 Posters 829 Views
    • ZeloksaZ Offline
      Zeloksa
      Hello M5Stack Community! πŸ‘‹
      What if your Cardputer could see through walls?
      I’ve been working on pushing the ESP32-S3 to its absolute physical limits and I'm excited to share WiFi CSI Radar ADV (V1.42). This firmware turns your device into a high-performance Channel State Information (CSI) radar that analyzes invisible radio wave reflections to detect motion and spatial presence.
      πŸ”₯ WHAT IT ACTUALLY DOES:
      πŸ›‘οΈ 1D Invisible Tripwire: Ultra-precise motion detection. It senses subtle movements (like walking or even breathing) through solid doors and walls. Perfect for perimeter monitoring.
      πŸ“ 2D Spatial Tracking (Active Beta): Tracks your physical position inside a room in real-time via a built-in Web UI by profiling Wi-Fi reflections in the corners of the room.
      πŸ—ΊοΈ Hybrid SLAM Room Mapping: Draw a digital floor plan of your environment simply by holding the device flat against your chest and walking around.
      βš™οΈ UNDER THE HOOD (For the Geeks):
      To make this work without lag, I had to bypass standard limitations:
      200+ PPS Capture Rate: Achieved the physical limit of the 2.4GHz stack.
      Dual-Core FreeRTOS Architecture: Core 0 handles aggressive radio/injection (NAT Bypass), while Core 1 crunches the heavy math and UI rendering.
      Smart Power Management: Advanced ADC noise filtering to prevent false charging detections under heavy Wi-Fi load.
      πŸ“₯ HOW TO INSTALL:
      The firmware is available directly in M5Burner.
      Open M5Burner.
      Go to the Cardputer -> User Custom (or Community) section.
      Search for WiFi CSI Radar ADV or Zeloksa.
      Burn and enjoy!
      πŸ“– MANUAL & FEEDBACK:
      Wi-Fi sensing requires exact calibration (e.g., leaving the room to set a baseline). Please read the full User Manual before your first launch!
      If you find bugs or have ideas for improving the 2D spatial math, drop an issue here:
      πŸ‘‰ https://github.com/Zeloksa/Cardputer-ADV-CSI-Radar
      β˜• SUPPORT THE PROJECT:
      If this tool helps with your research, pentesting, or hobbyist projects, consider supporting further development. It keeps the updates coming!
      πŸ‘‰ https://boosty.to/zeloksa
      Looking forward to seeing your test results and PPS records! Let me know how it performs on your local routers. πŸ“‘
      26af845f-65cd-4721-9fa2-830005bb0810-image.png 5b3fc7ba-112d-4a15-9332-ebd6ac4fe64d-image.png 93933263-d815-42fa-a37f-3782d85ad5d9-image.png
      Tags: Cardputer, CSI, Radar, ESP32-S3, Sensing, FreeRTOS
      With your input, this post could be even better πŸ’—
