    H-Bridge Unit v1.1 + M5Dial: possible library bug, HPWR issues & safety note — test report (please correct me if I'm wrong)
    1 Posts 1 Posters 167 Views
      HarzDevel
      Hardware: M5Stack Dial v1 (ESP32-S3) + M5Stack H-Bridge Unit v1.1 (STM32F030 + RZ7899, FW v2)
      Arduino Core: ESP32 3.3.7 | M5Unified: 0.2.15 | M5GFX: 0.2.21 | M5UnitHbridge: 1.0.0
      Overview
      We spent several sessions trying to get the H-Bridge Unit v1.1 working reliably with the M5Stack Dial v1. What started as a simple "connect and drive a motor" task turned into a systematic investigation of all possible port, voltage, and I2C combinations.
      This post documents the full test matrix with serial output and current measurements. We observed three things that surprised us — please read carefully and let us know if we misunderstood something or if there is a known solution we missed:
      1. The official M5UnitHbridge library does not seem to work with this hardware — we believe it is due to a missing Repeated Start condition in its I2C read implementation, but we may be wrong.
      2. Wire.begin() must be called after M5Dial.begin() — contrary to what you might expect, this re-configures the hardware I2C peripheral to Port A and works correctly. Is this intended behavior?
      3. HPWR mode does not behave as expected — forward direction produces no output, backward direction appears limited to ~9% effective duty cycle regardless of speed value. We tried PWM frequency changes, common GND, different ports and I2C methods — all without improvement. Could this be a firmware issue, or are we missing a required initialization step?
      We hope this is useful to others, and we very much welcome corrections or explanations from M5Stack or the community.
      TL;DR
      Getting the H-Bridge Unit v1.1 working with M5Dial is not straightforward. This post documents a complete test matrix covering all port/voltage/I2C combinations. The short version:
      • 5V mode + Hardware I2C (Wire) + correct registers = works, but USB power limits motor load to ~500mA
      • M5UnitHbridge library = broken for this hardware (wrong I2C read protocol, motor does not respond)
      • HPWR mode appears non-functional in FW v2: forward channel dead, backward works at fixed ~9% duty cycle regardless of speed value — firmware bug suspected
      Hardware Setup
      Item Detail
      Controller M5Stack Dial v1 (ESP32-S3)
      Driver M5Stack H-Bridge Unit v1.1 (STM32F030 + RZ7899, FW v2)
      Grove Port A SDA=G13, SCL=G15
      Grove Port B SDA=G2, SCL=G1
      HPWR supply 13.5V @ external terminals, 470µF cap across VIN+/GND
      Key Discovery 1: Wire.begin() After M5Dial.begin()
      M5Dial.begin() initializes the internal I2C bus (touch controller) on G11/G12.
      • Wire after M5Dial.begin() → internal bus, not Port A
      • Wire1.begin(13, 15) → G15 held LOW by touch controller → SCL blocked
      • ✅ Solution: Call Wire.begin(13, 15) after M5Dial.begin() — this re-configures the hardware I2C peripheral to Port A pins and works correctly
      auto cfg = M5.config();
      M5Dial.begin(cfg, false, false);
      Wire.begin(13, 15);
      Wire.setClock(100000);
      Key Discovery 2: Correct Register Map
      The H-Bridge register layout differs from various online sources. Verified by M5UnitHbridge library source:
      Register Address Description
      REG_DIR 0x00 Direction: 0=STOP, 1=FORWARD, 2=BACKWARD
      REG_SPEED8 0x01 Speed 8-bit (0–255)
      REG_SPEED16 0x02 Speed 16-bit little-endian
      REG_PWM_FREQ 0x04 PWM frequency little-endian
      REG_CURRENT 0x30 Motor current IEEE-754 float, 4 bytes (v1.1 only)
      REG_FW 0xFE Firmware version (uint8)
      Key Discovery 3: M5UnitHbridge Library Broken for This Hardware
      The official M5UnitHbridge library uses endTransmission() (with STOP condition) before requestFrom():
      // Library readBytes() — BROKEN for H-Bridge v1.1
      _wire->beginTransmission(addr);
      _wire->write(reg);
      _wire->endTransmission();        // ← sends STOP
      _wire->requestFrom(addr, length); // ← new START (not Repeated Start)
      The STM32F030 in the H-Bridge requires Repeated Start between write and read. Without it:
      • getFirmwareVersion() returns 255 instead of 2
      • Write operations appear to succeed but the motor does not respond
      ✅ Solution: Use Wire directly with endTransmission(false) for reads:
      Wire.beginTransmission(HBRIDGE_ADDR);
      Wire.write(reg);
      Wire.endTransmission(false);  // Repeated Start — NO stop condition
      Wire.requestFrom(HBRIDGE_ADDR, len);
      Complete Test Matrix
      # Port Pins Power I2C Result Notes
      1a COM A G13/G15 5V Hardware Wire ✅ Motor runs Brownout at ~78% load — USB 5V insufficient for full load
      1b COM A G13/G15 5V M5UnitHbridge lib ❌ No movement FW=255, writes silent. Library incompatible.
      2a COM A G13/G15 5V Bit-Banging ✅ Motor runs Brownout at ~24% — GPIO switching adds extra current spikes
      2b COM B G2/G1 5V Bit-Banging ✅ Motor twitches Brownout at ~25%, same as 2a. Port makes no difference.
      3a COM A G13/G15 HPWR Hardware Wire ❌ Forward only ~4mV FW=2 ✓, writes accepted (readback confirmed), forward channel inactive
      3b COM A G13/G15 HPWR Bit-Banging ⚡ Asymmetric Forward ❌ (4mV, inactive). Backward ✅ (-1.2V, 128mA, clean ramp to 255 and back)
      4 COM B G2/G1 HPWR Bit-Banging ❌ No movement Same HPWR issue, FW=2 ✓, readback correct, 79mA draw, 4mV output
      Serial Console Excerpts
      Test 1a — 5V, Hardware Wire, correct registers (motor runs, brownout at ~78%)
      FW-Version: 2
      [1] Vorwaerts: Rampe 0->255 (100ms/Schritt)
        write reg=0x00 val=1 ... err=0
        write reg=0x01 val=0 ... err=0
        spd=  0
        write reg=0x01 val=198 ... err=0
        spd=198
      E BOD: Brownout detector was triggered
      Test 1b — 5V, M5UnitHbridge library (motor does not respond)
      begin: OK
      FW-Version: 255   ← should be 2 — Repeated Start missing in library
        spd=  0 ... spd=255
      [2] Vorwaerts: halte 100% fuer 3s
      === Fertig ===
      ← no brownout, no motor current, motor never moved
      Test 4 — HPWR, Bit-Banging, with register readback (motor does not respond)
      FW-Version: 2  (read OK)
      [1] Readback-Test: dir=1 spd=128
        Readback: dir=1 (soll=1)  spd=128 (soll=128)   ← registers confirmed correct
      [2] Vorwaerts: Rampe 0->255 (100ms/Schritt)
        spd=0 ... spd=255
      [3] Vorwaerts: halte 100% fuer 3s
      Motor dreht nicht
      Messungen: 13.5V confirmed, 79mA from supply, 4mV at motor terminals
      Test 3b — HPWR, Bit-Banging, COM A (asymmetric: forward dead, backward works)
      FW-Version: 2
      [1] Vorwaerts: Rampe 0->255    → Motor does NOT turn, ~4mV at terminals
      [5] Rueckwaerts: Rampe 0->255  → Motor RUNS, -1.2V at terminals, 128mA from supply
                                        (~9% duty cycle at 13.5V, regardless of speed value)
      [7] Rueckwaerts: Rampe 255->0  → Motor slows cleanly and stops at spd=0
      Test 5 — HPWR, register snapshot (default PWM frequency)
      [R] Register-Snapshot (Firmware-Defaults):
        0x00 DIR   = 0  (0=STOP,1=FWD,2=BWD)
        0x01 SPD8  = 0
        0x02 SPD16 = 0
        0x04 FREQ  = 1000 Hz    ← default is audible range — explains motor beeping
      HPWR Mode — Appears Non-Functional in Firmware v2
      After extensive testing across all port/I2C combinations, our conclusion is that HPWR mode is functionally broken in firmware v2.
      Additional tests (Tests 5 & 6)
      • Default PWM frequency: 1000 Hz (register 0x04) — audible range, explains the motor "beeping"
      • Setting frequency to 10000 Hz: no improvement, forward direction still inactive
      • Connecting external supply GND to Grove GND: no improvement
      HPWR test results across all combinations
      Test Port I2C Forward Backward Notes
      3a COM A Hardware Wire ✗ 4mV n/a Writes confirmed OK via err=0
      3b COM A Bit-Banging ✗ 4mV ✓ -1.2V / 128mA Asymmetric — only backward works
      4 COM B Bit-Banging ✗ 4mV n/a Readback confirmed dir/spd correct
      Asymmetric behavior detail (Test 3b)
      Forward (dir=1):
      • ~4mV at motor terminals regardless of speed value
      • Brief 120mA spike from supply at spd=0–10, drops to 80µA by spd=40
      • Motor does not turn
      Backward (dir=2):
      • -1.2V at motor terminals — only ≈9% effective duty cycle at 13.5V supply, regardless of speed value (0–255)
      • 128mA from external supply
      • Motor runs through full ramp 0→255→0 and stops correctly
      • Requires a manual push past static friction at low speeds
      Evidence pointing to firmware bug
      1. I2C communication confirmed working (FW=2 readable, register readback correct)
      2. Speed value has no effect on output voltage in HPWR mode (9% fixed regardless of spd=1 or spd=255)
      3. PWM frequency change has no effect
      4. GND connection has no effect
      5. Issue present on both COM A and COM B
      6. Issue present with both Hardware I2C and Bit-Banging
      7. 5V mode works correctly on the same hardware
      Our interpretation: The STM32F030 firmware v2 may not properly implement HPWR mode — the DIP switch position appears to be detected but the RZ7899 drive logic may not be correctly configured for external supply operation. However, we acknowledge we could be missing a required initialization step or configuration. We would greatly appreciate clarification from M5Stack or anyone who has successfully used HPWR mode.
      Working Configuration (Minimal Code)
      #include <M5Dial.h>
      #define HBRIDGE_ADDR  0x20
      #define REG_DIR       0x00
      #define REG_SPEED8    0x01
      bool hb_write(uint8_t reg, uint8_t val) {
          Wire.write(reg);
          Wire.write(val);
          return Wire.endTransmission() == 0;
      bool hb_read(uint8_t reg, uint8_t* out) {
          Wire.write(reg);
          return Wire.requestFrom((uint8_t)HBRIDGE_ADDR, (uint8_t)1) == 1
              && (*out = Wire.read(), true);
          Wire.begin(13, 15);           // COM A, after M5Dial.begin()
          // DIP switch: 5V mode — HPWR forward channel does not work
          hb_write(REG_DIR, 1);         // FORWARD
          hb_write(REG_SPEED8, 128);    // 50%
      ⚠️ Safety Note: H-Bridge Runs Independently After ESP32 Reset
      The STM32F030 inside the H-Bridge has a lower minimum operating voltage than the ESP32-S3. This means:
      Scenario 1 — Brownout:
      The ESP32-S3 crashes (brownout at ~700mA from Grove 5V). The STM32F030 keeps running and holds the last direction + speed. The motor continues turning until power is physically removed.
      Scenario 2 — Reset button:
      Pressing the M5Dial reset button resets the ESP32-S3, but the STM32F030 is unaffected. Motor keeps running.
      Scenario 3 — Software crash:
      Any ESP32-S3 crash leaves the H-Bridge in its last state.
      Safe practice — always send STOP as the first action in setup():
      Wire.begin(13, 15);
      Wire.write(0x00); Wire.write(0);   // DIR = STOP
      Wire.endTransmission();
      Wire.write(0x01); Wire.write(0);   // SPEED = 0
      // ... rest of setup
      Current Measurements (5V Mode, Grove Side)
      State Motor Voltage Grove 5V Current
      Idle (M5Dial + H-Bridge logic) — ~300mA
      Motor running (after manual push) 3.3V ~700mA
      Brownout threshold (USB) — ~500mA
      Note: USB 2.0 limit is 500mA — sustained motor load exceeds this. Use a powered USB hub or a 5V supply with higher current rating. Do not rely on HPWR mode — it is non-functional in FW v2.
      Summary
      Issue Root Cause Fix
      Wire on Port A silent M5Dial.begin() uses Wire on G11/G12 Call Wire.begin(13,15) after M5Dial.begin()
      Wire1 SCL blocked Touch controller holds G15 LOW Don't use Wire1
      M5UnitHbridge FW=255 Library uses STOP instead of Repeated Start Use Wire directly with endTransmission(false)
      5V mode brownout USB 5V insufficient for motor load >~500mA Use powered USB hub or higher-current 5V supply
      HPWR mode non-functional STM32F030 FW v2 bug — forward dead, backward fixed at ~9% duty cycle regardless of speed No workaround — requires firmware fix from M5Stack
      Tested May 2026 on M5Stack Dial v1 (ESP32-S3) + H-Bridge Unit v1.1 (STM32F030 + RZ7899, FW v2) / Arduino IDE 2.3.8 / ESP32 Core 3.3.7 / M5Unified 0.2.15
      Appendix: Full Serial Output per Test
      Test 1a — COM A | 5V | Hardware Wire | correct registers
      === Test 1a: Wire direkt, korrekte Register ===
      FW-Version: 2
        spd=  0
        spd=198
      Lauf mit Ammeter (Grove-Seite):
        write reg=0x01 val=52 ... err=0
        spd= 52
      Strom: ~300mA Ruhestrom, ~700mA beim Laufen (nach Anschieben), 3.3V an Motor
      Test 1b — COM A | 5V | M5UnitHbridge Library
      === Test 1b: M5UnitHbridge Library ===
      begin: OK
        spd=  0 ... spd=255
      [3] Vorwaerts: Rampe 255->0
      [4] STOP ... [8] STOP
      === Fertig ===
      Test 2a — COM A | 5V | Bit-Banging
      === Test 2a: COM A | 5V | Bit-Banging ===
      [0] I2C Scan...  Gefunden: 0x20 <- H-Bridge
      FW-Version: 2
        spd=  0 ... spd= 62
      ← Motor dreht. Brownout bei spd=62 (~24%). GPIO-Umschalten erhoht Strombedarf.
      Test 2b — COM B | 5V | Bit-Banging
      === Test 2b: COM B | 5V | Bit-Banging ===
          SDA=G2 (gelb), SCL=G1 (weiss)
        spd=  0 ... spd= 63
      ← Motor hat gezuckt, Spannung messbar. Brownout bei spd=63, identisch mit 2a.
      Test 3a — COM A | HPWR | Hardware Wire
      === Test 3a: COM A | HPWR | Wire direkt ===
          SDA=G13, SCL=G15
      FW-Version: 2
        spd=  0 ... spd=255
      === Fertig ===
      Messungen: 13.5V OK, 0.083mA aus Netzteil, Motor dreht nicht.
      Test 3b — COM A | HPWR | Bit-Banging
      === Test 3b: COM A | HPWR | Bit-Banging ===
          SDA=G13, SCL=G15
      FW-Version: 2
      [1] Vorwaerts: Rampe 0->255   → Motor dreht NICHT, ~4mV, 120mA-Spike bei spd=0..10
      [5] Rueckwaerts: Rampe 0->255 → Motor dreht ✓, -1.2V, 128mA aus Netzteil
      [7] Rueckwaerts: Rampe 255->0 → Motor haelt sauber bei spd=0
      === Fertig ===
      Asymmetrie: Vorwaerts tot, Rueckwaerts ~9% eff. Duty Cycle bei 13.5V
      Test 4 — COM B | HPWR | Bit-Banging
      === Test 4: COM B | HPWR | Bit-Banging ===
        Readback: dir=1 (soll=1)  spd=128 (soll=128)   ← Register korrekt geschrieben
      [2] Vorwaerts: Rampe 0->255 ... Motor dreht nicht
      Messungen: 13.5V OK, 79mA aus Netzteil, 4mV an Motor.
      Test 5 — COM A | HPWR | Bit-Banging | PWM-Frequenz auslesen
      === Test 5: COM A | HPWR | Bit-Banging | FreqRead ===
          SDA=G13, SCL=G15
      FW-Version: 2
        0x01 SPD8  = 0
        0x02 SPD16 = 0
        0x04 FREQ  = 1000 Hz   ← default PWM frequency
      Motor dreht nicht.
      Test 6 — COM A | HPWR | Bit-Banging | PWM-Frequenz auf 10kHz gesetzt
      === Test 6: COM A | HPWR | Bit-Banging | FreqSet 10kHz ===
          SDA=G13, SCL=G15
      [F] Setze PWM-Frequenz auf 10000 Hz...
          FREQ nach Set = 10000 Hz   ← write accepted
      [R] Register-Snapshot:
        0x04 FREQ  = 10000 Hz
      [1] Vorwaerts: Rampe 0->255   → Motor dreht nicht. Frequenz hat keinen Einfluss.
