    ⚠️ M5Stack Core2 v1.3 - Ouroboros-like power loop -
    3 Posts 2 Posters 110 Views
    • Y Offline
      YO3HJV
      Hi all, I’m investigating a power management issue on the M5Stack Core2 (AXP192 + external SY7088 boost) and I’m looking for confirmation or a proper solution.
      🔧 System Architecture (as implemented)
      From schematic analysis and testing:
      AXP192 IPSOUT powers the system and the boost converter
      // VBUS ALWAYS INPUT ENABLED
       writeAxpReg(0x30, 0x80);
      SY7088 generates 5V (when EXTEN = 1)
      SY7088 output is directly connected to VBUS
      VBUS is also connected back into the AXP192 as an input
      ACIN is the real USB 5V input
      So effectively:
      BAT → IPSOUT → SY7088 → VBUS → AXP192 → IPSOUT
      ❗ Observed Problem
      When running on battery:
      -Enable 5V output (EXTEN = 1)
      -Disconnect USB cable
      -Immediately, battery current jumps to ~450 mA
      -System enters a self-sustained power loop
      🔍 Key Observations
      EXTEN is correctly set (verified via register dumps, Reg 0x12 bit 6)
      VBUS input is permanently enabled (Reg 0x30 = 0x80)
      Boost converter behaves normally
      Loop appears only when USB is disconnected
      💡 Root Cause
      SY7088 output is physically tied to VBUS
      AXP192 does not fully isolate VBUS internally
      The supposed N_VBUSEN mechanism does NOT break the electrical path
      🔥 As a result:
      BAT → boost → VBUS → AXP internal path → IPSOUT → boost...
      This leads to:
      continuous energy circulation
      high battery drain (~400 mA)
      no stable operating point
      ❓ Question to the community
      Has anyone:
      • Observed this behavior on Core2 or similar AXP192 designs?
      • Found a way to safely use 5V boost to power external accssories from battery without loop?
      Thank you,
      Cheers,
      Adrian YO3HJV
      • Y Offline
        YO3HJV
        Finally, I solved it...
        No need for 5V output on 5V_BUS because it came from magnetic base charger.
        Therefore an interlock code was added:
        --When 5V from battery is needed for external acc., VBUS== OFF & EXTEN==1;
        --When magnetic base charger (or external 5V is applied to Socket Power (J3) on Bottom2, VBUS == INPUT & EXTEN==0.
        This way, the Bottom2 LED's and othe devices are powered with 5V in any situation.
        Cheers,
        Adrian
          felmue @YO3HJV
          Hello @YO3HJV
          glad to hear you figured it out.
          I was just setting up a test to see if I get this 400 mA power loop too with my M5Core2; but I do not.
          When I set input mode I see about 82 mA drawn from the battery. When I set output mode I see about 99 mA drawn from the battery. (Note: an LED is connected to the Grove port.)
          In case your still interested in my UIFlow2 test program. It's in UIFlow2 Project Zone called: M5Core2_Input_Output_Test_UIFlow2.4.6
