How to use GPS module with SIM800L Module?
 I can't find the document. help me please.
 Change the pins for the GPS module as follows (by cutting the existing bridge and re-soldering). Only downside is, that the Serial monitor/output is not available anymore - RXD: 1
- TXD: 3
- PPS (not connected)
 Now, you can use the GPS module on the serial port 0: // The TinyGPS++ object TinyGPSPlus gps; // The serial connection to the GPS device HardwareSerial gps_serial(0); gps_serial(GPSBaud); // ... (within a loop/smart delay) while (gps_serial.available()) gps.encode(gps_serial.read());For the SIM800L you can use the regular configuration without changing anything: ... #define SerialAT Serial2 TinyGsm modem(SerialAT); TinyGsmClient client(modem); ...
 Thx sir.
 esptool.py v2.6-beta1
 Serial port COM3
 Connecting......................................_____A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header
 @poydevelop Try to clean the flash
 how to cutting the existing bridge?
  I re-soldering RX-1 and TX-3. is it correct?
 @poydevelop Need to cut the two lines which are RX-17, TX-16 with a knife first, then re-sold RX-1, TX-3
 @watson
 Thank you sir, knife it work.
