    UI flow IMU issues
    UIFlow
    12
    21.5k
    • H
      hetzer
      • Get Z function gives a number increasing constantly, exceeding 1000 over time.
      • Get Y and X functions provide different figures in each start with error of around 10 degrees.
      • Is calibration required or are there any other custom functions providing accurate results.
      • m5-docsM
        m5-docs @hetzer
        @hetzer Yes, It need to be calibrated after device initialization.
        M5Stack documentation URL
        https://docs.m5stack.com
        • H
          hetzer
          Is there a custom block for calibration. I like to use uiflow and prefer not to go back to arduino.
          • m5-docsM
            m5-docs @hetzer
            @hetzer Sorry about that I have asked engineer. He said that we'll not add this calibrated function block.
            • H
              hetzer
              Is it possible to get to gyro code coming with the firmware. I can see the the dafult gyro app is working accurately but all my get x and get y block resulting random numbers
              • m5-docsM
                m5-docs @hetzer
                @hetzer Are you sure that it is random data?
                • H
                  hetzer
                  Yes, en each start, while the unit is on the same position I get different values for x and y.
                  Z starts from zero and just increases in each measurement.
                  I tried to write a code to subtract the initial value from zero to calibrate but next x and y values within loop again starts from random values.
                  • H
                    hetzer
                    Still no solution to this problem, the demo is working flawlessly but get_x, get?y and get_z provide wrong results. Can anyone help?
                    • L
                      liushasha @hetzer
                      @hetzer Hi, thanks for your feedback, the block naming on IMU is misleading. get-x get-y get-z actually is Yaw, Pitch, Roll.
                      • H
                        hetzer @liushasha
                        @liushasha said in UI flow IMU issues:
                        I am aware but still the pitch and roll randomly varies around +-10 degrees and the roll value increase over time exceeding 360
                        • H
                          hetzer
                          Managed to get some more accurate x and ydegrees.
                          Is it possible to get yaw heading with uiflow?
                          • H
                            heybin
                            if only use mpu6050,i try fix yaw offset, but Failed .....
