    Neopixel units not working in uiflow 1.2
    15 Posts 4 Posters 25.3k Views 1 Watching
      ajb2k3 @m5-docs
      @watson said in Neopixel units not working in uiflow 1.2:
      Recommend to use FastLED library instead of neopixel library
      how do you use fast led in UIFLOW
      • lukasmaximusL Offline
        Noted, thanks for the heads up guys, and my apologies. I will inform the team and we'll get it sorted asap. @watson they are talking about no neopixel control in uiflow not in arduino
          Neopixel hex not working with M5Stick on Firmware 1.2.2 in UIFLOW!
          • m5-docsM Offline
            m5-docs @ajb2k3
            Hello @ajb2k3 Do you mean this unit?
            M5Stack documentation URL
            https://docs.m5stack.com
              ajb2k3 @m5-docs
              @watson
              Yes the Hex, was working fine before the 1.2 update.
              • m5-docsM Offline
                m5-docs @ajb2k3
                @ajb2k3 Have you connected HEX with the input direction?
                  As I said before, it was all working pre 1.2 via port A the i2c port.
                  • m5-docsM Offline
                    m5-docs @ajb2k3
                    @ajb2k3 As a software engineer told, version 1.2.2 has fixed this bug. You can try it.
                      ajb2k3 @m5-docs
                      Works with M5STACK
                      Does not work with M5STICK!
                      • m5-docsM Offline
                        m5-docs @ajb2k3
                        @ajb2k3 Does you keep M5Stick be lastest vesrion (v1.2.2) ?
                          ajb2k3 @m5-docs
                          @watson Yes,
