    69 Posts 7 Posters 452.1k Views 1 Watching
      ajb2k3 @GACHAPO
      • m5-docsM Offline
        m5-docs @GACHAPO
        @gachapo At main.c file
        M5Stack documentation URL
        https://docs.m5stack.com
        • G Offline
          GACHAPO
          Hi - Can't find main.c file. I've been into the downloaded fiirwares and I can't see it. Where am I going wrong please?
          • m5-docsM Offline
            m5-docs @GACHAPO
            @gachapo
            Download the firmware of ESP32CAM
            • G Offline
              GACHAPO
              ok - so if i amend the main file with my SSID and Password, save and then place the whole directory in the M5 burner directory, refresh the burner, delete the previous firmware on the camera, choose the new firmware and load will that work?
              m5-docsM 2 Replies Last reply Reply Quote 0
                ajb2k3 @m5-docs
                @watson I can't use the M5burner of the Stick C as it it coming up as
                Port: "dev/cu.serial-6D52F9B441
                instead of the expected
                Port: "dev/cu.SLAB_USBtoUART
                • m5-docsM Offline
                  m5-docs @ajb2k3
                  @ajb2k3 Are you working with Mac OS?
                    ajb2k3 @m5-docs
                    @watson
                    Yes, but is only the StickC that is giving the strange port ID.
                    All others report normal port.
                    • m5-docsM Offline
                      m5-docs @GACHAPO
                      @gachapo I means you can modify main.c file if you want to access other ip address during wifi setting instead of 192.168.4.1. Then compile the camera firmware again and burn it to ESP32CAM
                        salty_good
                        I understood this problem.
                        We need to fix M5Burner for mac.
                          ajb2k3 @salty_good
                          @salty_good said in [updated for Camera boards] M5 Burner Firmware Option Update:
                          Can you add drop down box to select port?
                          ポートを選択するためのドロップダウンボックスを追加できますか?
                          • m5-docsM Offline
                            m5-docs @GACHAPO
                              salty_good @ajb2k3
                              @ajb2k3 Off course yes,
                              and Baudrate also needs to be selectable.
                              • G Offline
                                GACHAPO @m5-docs
                                @watson Thanks - I have amended this. Am I best to use Arduino IDE to compile and upload? Currently when I use Arduino I have several error messages.
                                • m5-docsM Offline
                                  m5-docs @GACHAPO
                                  Hello @gachapo It's best to use esp-idf.
                                  • G Offline
                                    GACHAPO @m5-docs
                                    @watson Thanks- can you use arduino-ide?
                                    • m5-docsM Offline
                                      m5-docs @GACHAPO
                                      Hello @gachapo,
                                      Yes, Color recognition arduino program may help you.
                                      Here's the code:
                                      https://github.com/m5stack/Applications-cam/blob/master/Camera/M5CamColorRecognition/M5CamColorRecognition.ino#L36
                                      • G Offline
                                        GACHAPO @m5-docs
                                        @watson Thank you.
                                        Do I choose CAMERA_MODEL_WROVER_KIT?
                                        • m5-docsM Offline
                                          m5-docs @GACHAPO
                                          @gachapo
                                          You need chang this source code about camera hardware configuration for adapting to ESP32CAM. Because the arduino source code is for M5Camera A model.
                                          // Select camera model
                                          //#define CAMERA_MODEL_WROVER_KIT
                                          #define CAMERA_A_MODEL_M5STACK_PSRAM
                                          //#define CAMERA_MODEL_AI_THINKER
                                          • m5-docsM Offline
                                            m5-docs
                                            @GACHAPO @ajb2k3 Thanks your support
