    [Solved]Any way to know the name of the SSID and other info with wifisetup?
    Micropython
    6
    13.3k
    • f3rn4nd0dF
      f3rn4nd0d
      Hello, as the title of this thread says, I need to perform specific actions depending of the SSID name. Any help with wifisetup? Thanks a lot!
        salty_good
        @f3rn4nd0d You can get connecting SSID name and PSK on Arduino.
        #include <WiFi.h>
        WiFi.SSID()
        WiFi.psk()
        f3rn4nd0dF 1 Reply Last reply Reply Quote 0
        • f3rn4nd0dF
          f3rn4nd0d @salty_good
          @salty_good thanks, but I'm developing a little client in python that will connect to several wifi networks. The idea is to publish a different message via MQTT depending of the wifi it has connected to. I need to do it in python, maybe I can import a different library that gives me more options than wifisetup.
          F.
            ajb2k3 @f3rn4nd0d
            @f3rn4nd0d I'm looking at something similar but using RSSI.
            For micropython I have been visiting the micropython forum.
            link text
            • lukasmaximusL
              Hi @f3rn4nd0d there is a wifi scanner script that comes with the uiflow firmware, heres the python code in that file, hope it helps.
              from m5stack import *
              import network
              import utime as time
              lcd.clear()
              sta = network.WLAN(network.STA_IF)
              sta.active(True)
              while True:
                  lcd.clear()
                  lcd.setCursor(0, 0)
                  lcd.print('wifi scan:')
                  wifi_list = sta.scan()
                  number = 1
                  for i in wifi_list:
                      lcd.print(i[0].decode(), 20, number*13)
                      number += 1
                  time.sleep(10)
              • f3rn4nd0dF
                f3rn4nd0d
                Well, I've managed to do on a different way, thanks a lot for your help. Here is the code:
                #import wifisetup
                #wifisetup.auto_connect()
                import network
                from m5ui import *
                from m5_pin import *
                from m5mqtt import M5mqtt
                from time import strftime, ticks_ms, ticks_diff, sleep_ms
                import utime
                import _thread
                def connect(ssid,auth,timeout=6000):
                    from network import WLAN, STA_IF, AP_IF
                    global uplink
                    uplink = WLAN(STA_IF)
                    uplink.active(True)
                    uplink.connect(ssid, auth)
                    started= ticks_ms()
                    while True:
                        if uplink.isconnected():
                            return True
                        else:
                            if ticks_diff(ticks_ms(), started) < timeout:
                                sleep_ms(100)
                                continue
                            else:
                                return False
                wlan = network.WLAN(network.AP_IF)
                while True:
                  if connect('Wifi1', 'password1'):
                    red='Wifi1'
                    break
                  elif connect('Wifi2', 'password2'):
                    red='Wifi2'
                    break
                print('connected to: ',red)
