    [closed] Images not working
    12 Posts 3 Posters 22.9k Views 1 Watching
      I'm trying to load an image but everytime I use the blocky version of this code
      from m5stack import *
      from m5ui import *
      clear_bg(0x222222)
      btnA = M5Button(name="ButtonA", text="ButtonA", visibility=False)
      btnB = M5Button(name="ButtonB", text="ButtonB", visibility=False)
      btnC = M5Button(name="ButtonC", text="ButtonC", visibility=False)
      image1 = M5Img(64, 19, "res/miniM5os.jpg", True)
      lcd.fill(0x3333ff)
      image1.changeImg("res/miniM5os.jpg")
      image1.setPosition(0, 0)
      while True:
        image1.show()
        wait(1)
        wait(0.001)
      I just get a blank black square on the screen.
      • lukasmaximusL Offline
        working fine for me. are sure you did all the steps, manager > upload less than 25 kb image > drag an image placeholder on UI area, select it and choose your uploaded image from the dropdown list? I have occasionally had weird results from certain files. Have you tried other files beside the one your trying to display?
          ajb2k3 @lukasmaximus
          @lukasmaximus It will only allow me to upload BMP or JPG but Bmp have to be super compressed.
          Yup followed those steps but just get a black odd shaped box.
            salty_good @ajb2k3
            @ajb2k3 I had seen a tweet on twitter.
            JPG format needs some conditions.
            ・progressive off
            ・not Matte color
            and use MS paint is no problem.
              ajb2k3 @salty_good
              @salty_good said in Images not working:
              ・progressive off
              ・not Matte color
              i'm on osx and using G.I.M.P
                Is there a detailed specification for images somewhere?
                  salty_good @ajb2k3
                  @ajb2k3 i found out this.
                  https://github.com/loboris/MicroPython_ESP32_psRAM_LoBo/wiki/display#tftimagex-y-file-scale-type
                  • JPG images are supported.
                    Baseline only. Progressive and Lossless JPEG format are not supported.
                    Image size: Up to 65520 x 65520 pixels
                    Color space: YCbCr three components only. Gray scale image is not supported.
                    Sampling factor: 4:4:4, 4:2:2 or 4:2:0.
                  • BMP images are supported.
                    Only uncompressed RGB 24-bit with no color space information BMP images can be displayed.
                    ajb2k3 @salty_good
                    Ahh Lobo had the specs listed. thanks mate.
                      Working now.
                        salty_good @ajb2k3
                        @ajb2k3 Great!!
                          Is there a good tool in GIMP for compressing image files? @ajb2k3 I tried without success in photoshop before, perhaps its there but I don't know. It would be better however to have an open source solution such as gimp
                            @lukasmaximus some formats gimp can compress, others need understanding of the file formats.
