    [Solved]Ui Flow - encoder support
    Scheduled Pinned Locked Moved FACES Kit
    7 Posts 4 Posters 13.7k Views 1 Watching
    • OyczEO Offline
      OyczE
      Hi there !
      there is any plans to add support for https://docs.m5stack.com/#/en/module/encoder inside the Ui Flow ?
        From what I understand, the faces units are aimed more towards industrial and so are unsupported in UIFlow.
        • L Offline
          LastCaress
          I think it'd be possible to write custom blocks for it
            If you do it, or start it, post it in the Projects forum.
            UIFlow is built on Micropython so I sure that you are correct.
            • L Offline
              LastCaress
              I figured out how to read the values from the encoder. My encoder is kinda crappy though, always a bad connection
              • L Offline
                LastCaress
                So, in flow:
                import i2c_bus
                i2c_l = i2c_bus.get(i2c_bus.PORTA)
                b = str(i2c_l.readfrom(0X5E,3))
                moving = b[4:6]
                clicking = b[8:10]
                I'm sure there's a better way to do this (with proper encoding). Clicking returns "1" if there is no clicking and "0" if there is. moving forward is 1,2,3,4,5 depending on speed and ff,fe,fd, etc... if it's going backwards.
                Should be simple to do a blocky version of this!
                • m5-docsM Offline
                  m5-docs
                  Yes, you can custom serials of blocks for FACES Kit.
                  M5Stack documentation URL
