    Relay on I2C port cause M5Go to restart.
    Units
    13.0k
      I'm testing the relay on Port A as its listed as a digital I/O port.
      When triggered the relay works fine but when it releases the M5Go restarts.
      Is this just me or an issue with the relay module.
        Ok its missing the back feed diode.
        • m5-docsM
          m5-docs
          Hello @ajb2k3,
          I remembered the question you said.
          Anti-back charge diode.
          Is it convenient for you to give detailed information? Especially the photos
          M5Stack documentation URL
          https://docs.m5stack.com
            ajb2k3 @m5-docs
            @m5-docs I sent the diagrams to the support operator.
            It is fine on the I/O port (B) but on A it cause the trip. I am worried that this could cause premature failure of io pins.
            • m5-docsM
              m5-docs @ajb2k3
              @ajb2k3 the support operator?
                heres an image showing the flyback/bypass diode missing from the relay
                alt text
                m5-docsM 2 Replies Last reply Reply Quote 0
                • m5-docsM
                  m5-docs @ajb2k3
                  @ajb2k3 Thanks a lot !
                  • m5-docsM
                    m5-docs @ajb2k3
                    @ajb2k3 Can I know the source of your picture?
                    ajb2k3A 2 Replies Last reply Reply Quote 0
                      ajb2k3 @m5-docs
                      @m5-docs said in Relay on I2C port cause M5Go to restart.:
                      Sorry, Gimme a sec to find it. Its a common diagram of the flyback/bypass diodes connected in relay modules
                        ajb2k3 @m5-docs
                        @m5-docs https://electronics.stackexchange.com/questions/115857/flyback-diodes-and-relays
