    [Solved]Disable battery
    Cores
    15.3k
    • D
      DavMartEs
      I’m building a project to place it in a car dashboard and I am wondering if the internal battery of the basic M5Stack Core can be disabled.
      The reason is that I only want the device to be on when car power is sent through usb c cable and off as soon I switch off the car power when locking car doors.
      Does anyone knows how can I disable the internal battery without having to press a button? Thanks
        ajb2k3 @DavMartEs
        @davmartes you could Unplug the battery?
        I think there is also a way to mimic the power button to do it
          I would leave it connected and have an abortable shutdown timer like on some sat navs
          • m5-docsM
            m5-docs
            @DavMartEs It's better to cut off the power cord of battery.
            M5Stack documentation URL
            https://docs.m5stack.com
            • D
              DavMartEs @m5-docs
              @m5-docs great, thank you. Do you have any picture or diagram that shows the location of the cable?
              • m5-docsM
                m5-docs @DavMartEs
                @davmartes According to the following pictures, you can cut off the red cable of Battery
                or cur off the pin named "BATTERY" on M5-Bus
                M5-Bus
                D 2 Replies Last reply Reply Quote 0
                • D
                  DavMartEs @m5-docs
                  @m5-docs Thank you very much. Very useful diagram and pictures
                  • D
                    DavMartEs @m5-docs
                    @m5-docs what about M5StickC? Is it possible to do the same? Do you have a diagram?
