    [Solved]sleep mode on MircoPython?
    Micropython
    13.2k
    • A
      akita11
      We can use DeepSleep mode on MicroPython as described here:
      https://github.com/loboris/MicroPython_ESP32_psRAM_LoBo
      Is there any way (modules) to handle light sleep mode in MicroPython?
      Other version of ESP32's MicroPython provides machine.lightsleep().
      http://vcc-gnd.com/rtd/html/esp32/quickref.html?fbclid=IwAR3ChQc9samG9iNG9IFTRGypX_zqD43d8QweAeWI5OUKRuCgGxvKaHxDXE8
      • m5-docsM
        m5-docs @akita11
        @akita11 Yes, as http://vcc-gnd.com told, use the following code
        import machine
        will enter light sleep mode
        M5Stack documentation URL
        https://docs.m5stack.com
        • A
          akita11 @m5-docs
          @m5-docs No, I'm using the newest MicroPython on M5stack, but "machine" has no member of "lightsleep()".
          • m5-docsM
            m5-docs @akita11
            Hello @akita11
            Which version are you using? Here's mine.
            • A
              akita11
              @m5-docs Thanks, mine's version is: "MicroPython ESP32_LoBo_v3.2.24 - 2018-09-06 on M5Stack with ESP32", that is distributed for UI flow 1.2.3.
              I burned UI flow 1.3.0-beta, and found machine.lightsleep() is available.
